LCD Technology refresh rates
Discussion in 'LCD & LED LCD TVs' started by NeilGriffith, Apr 5, 2005.
  1. NeilGriffith
    NeilGriffith
    Feb 16, 2005
    12
    Does anyone know of any LCD monitor/screen that will support a resolution of 1280 x 1024 and 90HZ+ Vertical refresh frequency?
    Currently I am using a CRT monitor to display Stereo images, and for the stereo to work work correctly flicker free the refresh rate should be 90Hz at a minimum.
    Many thanks
    Neil
  2. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    LCD's don't flicker, either connect via DVI @ 60Hz or D-Sub @ 75Hz, DVI is the way to go though, IMHO.
  3. NicolasB
    NicolasB
    Oct 3, 2002
    5,804
    Emily's Shop
    +520
    It's nothing to do with flicker, he's using shutter glasses to produce a true 3D (stereoscopic) picture - alternate frames viewed by each eye.
    I'm afraid he's not going to get this to work on an LCD display, though. :( The latency is simply too high.
  4. NeilGriffith
    NeilGriffith
    Feb 16, 2005
    12
    Can you explain what you mean by Latency???
    Neil
  5. MorseKode
    MorseKode
    I believe he's referring to the response time - a decent LCD screen (with a response time of around 15ms) will be too slow to synchronise with the shutter glasses, resulting in the picture being a frame or so behind the glasses. It wouldn't look nice.
    There are also polarisation problems with LCD glasses and LCD screens. Perhaps they've fixed it now. But you might not be able to see anything (unless you turn your head at an angle, thus negating the stereo effect!).
    This is probably not what you wanted to hear, sorry. There are some 3D monitors out there which do not require glasses at all, but I'm sure they are very expensive (and not TVs).
  6. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    When I bought my SGI workstation about 5 years back I was going to go for the stereo glasses. However since I went with the LCD monitor, it was not an option. I think this was due to incompatibilities with the two technologies.
  7. LcdGuru
    LcdGuru
    LCDs are too slow to refresh at 90Hz = 11ms field period.
    You need a nice sharp transition from one frame to the next - to sync up with the left/right shutter on the 3D glasses. An LCD may take up to 20ms to respond (depending on greyscale transition) so you'd end up with a blurred combination of the left and right images.
    You might be able to do it with a plasma - not sure if they can reach 90Hz though.
