LCD Smearing?
Discussion in 'LCD & LED LCD TVs' started by remdude, Aug 1, 2004.
  1. remdude
    remdude
    Jul 21, 2004
    67
    Hi have just purchased a Panasonic LCD TV, Model No: TX-32LDX1.
    I am extremely happy with the set when watching SKy via the RGB scart. But when I watch some DVD's (don't laugh, Dumb and Dumber and Babylon 5 Box Set) I get some sort of picture distortion, I think its refered to a smearing, basically peoples foreheads are staying still while the face moves around it, it looks really wierd.
    However, when I watch newer DVDs, such as Lost In Translation and Underworld I dont get this distortion, nor when Im watching Sky. My DVD player is a Pioneer 575A and im using compenent out (it makes no difference if I use pregressive or interlaced output).
    Why does this distortion only occur on some DVDs and not others, and is there a way to minimise it?
    Thanks for your help
    REMDUDE
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    12,752
    Somewhere in South Yorkshire
    +4,906
    Sounds like it's a noise reduction feature (probably in the TV) that's trying to remove something it thinks is noise (grain) but isn't. Not familiar with this set, but if there is a menu option which seems to be anything to do with picture noise reduction (and it may be called by any sort of odd name - the manual might help by describing what certain options actually do) turn it off and leave it off. Check the DVD player out for something similar, too.
  3. remdude
    remdude
    Jul 21, 2004
    67
    Cheers Nigel, I turned off the BNR setting on DVD player and this worked a treat.
    Thanks again.
    REMDUDE
  4. LV426
    LV426
    Jul 14, 2000
    12,752
    +4,906
    Good. On the whole, DVDs should produce a clean, noise-free image anyway. So, I'm a bit mystified as to why DVD player mfgs feel it necessary to provide such a feature. In general, a good LCD will be (in some respects) more revealing of artefacts in the signal than a CRT. Pretty much anything in the source that "processes" the signal is best left off.
  5. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Funny how keen all the manufacturers are on signal processing, when most agree it's a bad thing. Not mentioning any large Dutch companies here of course, as being a prime example.
  6. Beck
    Beck
    Hi guys,
    I'm interested in your discussion of the Panasonic TX32LXD1 having had mine delivered over the weekend. Although extremely pleased with the styling the picture quality is leaving me cold at the moment. I'm experiencing significant smearing while watching Sky and am desperately hoping there are settings I can tweak to recify the problem. It's a shocking waste of money if not. I would be grateful for any advice on this as I'm very much an amateur in this area and don't really know where to start......
