Lcd Size For Room
suni
ive posted up a few times now, but as im sure you all know the more you research you do the more questions you get, on my part this is becoming indecision now.
I want to get a LCD tv in the near future. its going to be in my bedroom and hooked up to an xbox360. will be watching dvds throught the xbox aswell.
well just a quick few questions, the bedroom is 16 ft by 16 ft. so its fairly large. i will probably be 10-12 ft away from the tv. Will a 32" tv be big enough for a room this size? or is a 37" - 40" suit the room better ?
secondly on my shortlist of tvs is,
TOSHIBA 32WLT58
SAMSUNG LE32M61
SAMSUNG LE40M61
SONY KDLV33A12U
SONY KDLV40A12U
PHILLIPS 32PF9830
PANASONIC TX-32LXD500/600
BUDGET IS £1200 TO £2000
from the tv im looking for great performance with the xbox360, good colour display, and no motion blur with fast moving scenes and of course great h-def diplays
would appreciate all feedback and opinnions
Tempest
To be honest, if you are sitting 10ft to 12ft away I'd say you're not going to get the best from a 32" screen.
I'd say go for a 37" (42" possible overkill depending on room design/layout)
If you sit too far away you're not really going to appreciate the quality a modern hi-def set (potentially) can give you.
I have mine (37" Tosh) set up for a 9ft viewing distance, and I'd say it's perfect at this distance.
For me, I find the "typical" moans about quality of terrestrial TV dissapear at 3x from screen.
I have heard (from others) a good rule of thumb (with modern LCD's) is 3x screen size = ideal viewing distance.
So, using that formula: 37" x 3 = 111" or in other words 9.25ft
As you can see, I'm almost spot on this 3x calculation.
Trust me, if you get a 32" after a few days/weeks you're gonna start thinking, oh perhaps I should have got a larger one.
Just my thoughts. As for me, even at 9ft away, I would not want a 32" screen if I wanted to "ENJOY" my viewing. Don't get me wrong, a 32" would be easily viewable, but you'd get INTO the program more by going up a step.
Just my thoughts.
======== EDIT ========
Just read the end of your post:
The Toshiba 37" would exactly hit the bottom of your budget, It gives a SUPERB picture via component from an Xbox360, no tearing/smearing issues I have ever noticed on games.
