LCD Screen suggestions
Discussion in 'LCD & LED LCD TVs' started by elmbeck, Nov 22, 2003.
  1. elmbeck
    elmbeck
    Sep 23, 2002
    347
    Avonbridge
    +10
    Can anyone suggest a decent LCD Widescreen for less than £1,000.
    The wider the better (not expecting to match the 42 Panny Plasma downstairs - but not wanting to use binoculars in the bedroom)
  2. Rajibear
    Rajibear
    Nov 1, 2003
    149
    16
    Ive got a Sony KLV HR2 in my bedroom and am happy with it. The only problem ive experienced although this may be common amongst all LCd TV is that in the dark particularly it is difficult to make out dark scenes as well as I hoped.
  3. Rajibear
    Rajibear
    Nov 1, 2003
    149
    16
    that is 17HR2
    rajibear
  4. elmbeck
    elmbeck
    Sep 23, 2002
    347
    Avonbridge
    +10
    Thanks...... I am looking for something bigger than a 17 inch..... getting on a bit - eyesite not as good as it used to be.
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    If you can find one, Sharp LC22SV2e for a grand buy it!!!! £1200 most places IIRC but search around and see great set!!!
