lcd screen shake with pal
Discussion in 'LCD & LED LCD TVs Forum' started by simon13, Apr 29, 2007.
Tags:
  1. simon13
    simon13
    hi,i`ve just installed a tevion tv 47" lcd, which uses an lg screen (lc470wu1)
    the picture from a dvd player is spot on, no problems.
    when i watch my sky(amstrad drx100, approx 10 years old )via the rgb setting the picture has a slight yellow tinge,if i switch to pal the picture quality is perfect except the picture continually flickers to the left, hardly noticeable when watching moving pictures but really irritating when viewing banner boxes or sky tv guide.
    i have used the same scart lead for watching the dvd picture as the sky picture so i`m guessing there should`nt be a problem with the lead.
    any suggestions!!!!!!
    cheers.
  2. simon13
    simon13
    just to let you know i connected a panasonic sky box to the telly and both rgb and pal outputs are perfect there must be a compatability problem between the television and the amstrad decoder....so, sir alan "your fired"
  3. bubbaphatass
    bubbaphatass
    Jul 10, 2006
    259
    +16
    I had the same problem before I took the screen back, I think it was something to do with using a RGB signal on the non-rgb scart, or something like that.
