LCD Sceen Cleaning
Discussion in 'LCD & LED LCD TVs Forum' started by RyanK, Oct 20, 2005.
Tags:
  1. RyanK
    RyanK
    Sep 20, 2005
    1,104
    London
    +38
    Can anyone recommend a good cleaner and cloth for cleaning my LCD screen?
  2. mike7
    mike7
    Jan 3, 2005
    4,949
    Norfolk
    +618
    Avoid Brillo pads ........
  3. Cynthia 7
    Cynthia 7
    Hi RyanK,
    I read that for LCD screens use a spectacle lens cleaner and cloth obtainable from opticians. I made a note of it as I am shortly to buy an LCD tv for my kitchen and I thought it would need regular cleaning in that room.
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    Just get any micro fibre cloth and avoid any cleaning solutions. Just use the slightly damp cloth with water.
  5. chambeaj
    chambeaj
    Jan 1, 2005
    3,055
    +190
    I only use a spectacle lens cleaning cloth and nothing else to dust the screen.
    If necessary (i.e. a mark/fingerprint has appeared) dampen the cloth a bit first. Never leave water droplets on the screen though!!
    Should not use sprays/chemicals (unless they are specifically stated as suitable for cleaning LCD screens - personally I avoid them altogether) - you can cause chemical damage to an LCD screen - even water droplets should not be allowed to simply dry out.
  6. Smiffy 2
    Smiffy 2
    Nov 20, 2004
    1,922
    2
    Bexhill on Sea
    +303
    My new Sammy came with it's own cleaning cloth, and the instruction booklet suggests just using this, slightly dampened with water.
  7. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Yep, micro fibre (e-cloths) are great and leave a streak/smear free finish. Just make sure you get the right variety as there seems to be versions for different applications now, including your body parts. The one that I use is for stainless steel applicances and really fine - its the 'smooth' blue one. They cost less than a fiver (I have actually seen them for a couple of quid somewhere but forgot where) and will last for years. They require an absolute minimum amount of water (don't spray the screen but add just enough water to make the cloth slightly damp) so are effectivly free in use and very environmentally friendly. Plus you can use them for many other tasks too. www-e-cloth.co.uk for more info and your local hardware/kitchen store to buy.
  8. Woodywizz
    Woodywizz
    Aug 18, 2005
    12,422
    Manchester
    +6,172
  9. Promised Land
    Promised Land
    May 4, 2004
    215
    16
    The Thin Line
    I have the same one.The sheet that came in the pack said it was to clean the black surround though,not the actual screen itself.Whether it's suitable or not,I'm really not sure.
