LCD questions
Discussion in 'LCD & LED LCD TVs' started by NickXX, Jan 3, 2005.
  1. NickXX
    NickXX
    Hi all,
    I bit the bullet, and bought a 27" Tosh (27WL46) from Comet. Was going to wait for the 32WL48 to drop, but these things are going for £800 at the moment. Anyway, I'm very happy with it using it with a Panasonic Digibox and my PC (using the DVI input), but have a couple of q's.
    Is it possible to output a 1280x720 (the panel's native res) over a DVI connection? I'm currently using the DVI connection to output a 1024x768 signal from my PC. I've tried to output the higher resolution with Powerstrip with no luck.
    Also, it says in the manual that I shouldn't leave the TV on standby over night. Will this really damage the panel? I have it in my bedroom, and don't really want to get out of bed to turn it off before I go to sleep..
    Many thanks in advance!
    Nick
  2. miika
    miika
    Jan 18, 2005
    23
    3
    Tampere, Finland (EU)
    It is possible to use 1280x720, but first the EDID of the display must be bypassed (or, in the future, updated).
    See:
    http://www.entechtaiwan.net/forums/viewtopic.php?t=1970&postdays=0&postorder=asc&start=15
    An to the standby question, I never shut down my TV; it's always in standby when not in use. Since the background light is not on when in standby, I wouldn't be so worried about it.
