Lcd Question
Discussion in 'LCD & LED LCD TVs Forum' started by steevs, Sep 21, 2004.
Tags:
  1. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Hi all.
    I'm looking at venturing into the lcd market, main thing I would be using it for is pc gaming, I was wondering if these were suitable for that as most I have looked at on the net make no mention of a pc input.
    I was thinking of maybe the Hitachi 22LD4200 or the Jvc LT-26C31, I have looked at dedicated tft monitors but would much prefer an lcd tv as I want to watch Tv on it too.
    Anyways I was wondering if anyone had any reccomendations, I have about £1500 to spend and the larger the screen size the better as far as I am concerned.
    Steve :)
  2. Bob Todd
    Bob Todd
    Aug 20, 2000
    3,109
    UK
    +369
    what you need to do is write down what percentage of its use the TV will be used for?
    i did this with my 19" Iiyama C480T, I wanted a screen that I could use 60% for PC 30% for xbox and DVD movies and 10% for TV, IIyama always make good PC monitors and it had component inputs for the Xbox, and has a farouja scaling chip inside for none native resolutions ala TV 720x576.
    seeing as you want to play PC games the most u need to find reviews of what their like as PC monitors, especially do they suffer from ghosting.
    my C480T was rated 5/5 from the guys behind this forum, and it suffers a little now and then.
  3. steevs
    steevs
    Jan 3, 2003
    2,910
    68
    wxm
    +72
    Thanks for the reply, i'll look into that.
