LCD projector help plzz
S
SRT4U2NV
Hello, im knew to these forums. im having problems with an NEC VT660K. It's used. i have it plugged in and when i turn it on it shows a yellow light on the power button. when when i push power it dosent fire up. fans dont turn on or anything. it just sits in standby mode. what could be the problem? anyhelp is greatly appreciated.
stevelup
A common problem with NEC projectors (and others) is the filter door.
There is a tiny switch inside the door that holds the filter - if the door is broken or not properly shut, the projector will fail to start.
Steve
S
SRT4U2NV
yeah well i tried makin sure the filter piece is in all the way but still no luck. anything else i can do or suggestions cuz its very agrivating to have this and not come on. thanks
MikeK
This may seem a bit silly to ask, but are you holding the power button down for a few seconds (it takes a couple of seconds of being held down - this is to prevent accidental powerup).
Failing that, try removing and reinserting the lamp (there is an interlock switch inside the housing).
derillio
Hi, Long shot question, Do you still have the NEC VT660K? i'm looking for a broken one to break for part's. Many Thanks
⭐ Philips OLED+908 TV preview + Avid Accent amplifier reviews + Hi-Fi & AV News
Back
