lcd or plasma which is best???????
Discussion in 'Plasma TVs Forum' started by richmondo, Dec 20, 2006.
  1. richmondo
    richmondo
    Dec 19, 2006
    53
    im looking to buy a lcd or plasma 37" around £1000 but am unsure which to go for. I know both have good points and bad points but which ONE???? Has anyone out there got any recommandations please please help
  2. marvinwright1
    marvinwright1
    Mar 1, 2004
    331
    28
    +53
    Hi Richmondo,
    It may help if you give some information as to how you are going to use it, i.e. what sources you are going to feed it with.
    My personal preference is plasma but each person probably has their own opinion. I'd strongly recommend going to an av shop and demoing some LCD's / Plasmas within your budget, then you can make up your own mind.
    Marvin.
  3. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    Welcome Richmondo! Have a go with the search function - this is a very widely discussed topic and will depend upon your usage.
  4. richmondo
    richmondo
    Dec 19, 2006
    53
    hello marvin thanks for your reply i like the look of the Panasonic TH37PX60 but am slightly put off by the glass front reflection and also am not sure how good it is with sky digital and xbox 360 which im getting next year.
    Richmondo
  5. richmondo
    richmondo
    Dec 19, 2006
    53
    has anyone heard anything about the toshiba 32/37wlt68 lcds
    pioneer vsx 515 amp yamaha speakers yamaha sw p130 sky digi panisonic dmr-e50 dvd recorder
  6. richmondo
    richmondo
    Dec 19, 2006
    53
    hello ahaydock thanks for your reply which is your preference also dumb question how to use the search function??????????????
    richmondo
  7. metin
    metin
    Jul 31, 2004
    122
    +3
    plasma by miles............. but the LCD guys may have debate. LCD are good for small screens, thats my opinion. plasma is much sharper and can handle motion alot better than LCD. go and demo both and see what you find!
  8. Bumtious
    Bumtious
    Oct 26, 2005
    8,126
    Prestwich Manchester
    +7,650
    The choice is really yours.
    Whichever one you think it looks better, then buy it.
    It's going in your room not mine.
    However if I was in the shop with you I will have put you off LCD within a minute.
    1 Look at the tv from the side at about 30 dgrees.
    2 Look at the tv with contrast down to a level where you don't need sunglasses.
    3 Look at the tv with BBC freeview and ITV freeview.
    4 Then look at a plasma doing the same
    Nuff Said.
  9. ahaydock
    ahaydock
    Nov 16, 2005
    1,590
    Dorset
    +177
    To be honest if it was me it would be Plasme, and probably a 42" Panny (PX60) or a Pio. Both will be great with the 360 and Sky!
