I'm on the verge of buying a 37" HD-ready TV, I believe that support for 720P is going to be fine for me... may get an Xbox360 in the coming year.
My first question is that LCD screens seem to have a slightly higher resolution than the plasma equivalents, does this have a noticeable impact on picture quality? i.e. is the picture sharper on an LCD because of this? I would assume the higher the resolution the better, is this something I should be concerned about?
Next up is, I keep looking through lots of great and informative reviews, but its difficult to pin down what is a good buy right now i.e. currently available and comparable to other recent models.
Basically I'm looking to narrow down my search to 2 or 3 models of either LCD or Plasma and my requirements are that it has a good quality built-in Freeview tuner, will display a 720P image, has a sensible range of inputs i.e. single HDMI and it is a recognised brand i.e. Tosh, Samsung etc. My budget is £700 - £800. Eventually it will be used with a HD-DVD player, prob 2nd half of next year.
Any advice would be very much appreciated.
One last question, is it true that plasma tv's are significantly heavier than LCD screens?
Thx in advance.
Thx in advance.
