LCD or plasma 1080p
knoxundead
Although we are half talking about plasmas here this seemed the best forum for it....
I'm trying to select a new tv and ive narrowed it down to a few options:
Plasma
http://www.1staudiovisual.co.uk/catalog/panasonic-th42pz80-inch-plasma-p-3288.html
http://www.1staudiovisual.co.uk/catalog/panasonic-th42pz85-inch-plasma-p-3295.html
LCD
http://www.1staudiovisual.co.uk/catalog/samsung-le40f86bdx-inch-p-2301.html
http://www.trustedreviews.com/tvs/review/2008/04/12/Samsung-LE40A656-40in-LCD-TV/p1
I'm trying to keep it under £1000. I will be using this tv for high def gaming, movies and general computer use all connected by hdmi. Right now I'm leaning towards the Samsung-LE40A656 but I will need to wait for it to go down a little in price.
Which normally looks better when using a computer 1080p dvi output, plasma or lcd?
Any help you could give would be great!
badbob
Having owned a Samsung LCD, I'd choose the plasma. However you're using it with a computer, so for that I'd get the LCD. Maybe buy both, go dual view, plasma for movie playback (secondary) and the LCD for desktop (primary) :thumbsup:
knoxundead
Badbob I aint made of money ;)
Nielo I think that panel is starting to show its age and will £750 is a good price I'm trying maxamise my spending power to get the best tv for my money. Also I just found this...
Samsung-LE40A656
Normally £1099. Use codes SAM5L and
BIGTV at checkout & buy for £1024
www.dixons.co.uk
Damn good deal...
ChrisGgr
I d get an lcd for these uses.Apart the 40A656 also consider the brand new Sony KDL-40W4000
knoxundead
Had a look at that set but thought that the samsung seemed to have the edge.
One question I forgot to ask is does anyone know if the samsung have 1:1 pixel mapping?
ChrisGgr
Dont djudge before you see but anyway the samsung does 1:1
AVForums Movies Podcast: We review Dune and ask which is the best decade for horror movies?
