LCD monitor (not tv) for DVD and no tv licence
Discussion in 'LCD & LED LCD TVs' started by mariot, Apr 2, 2005.
  1. mariot
    mariot
    Is it possible to connect an LCD - TFT type monoitor to a DVD player and therefore do away with the need for a tv licence.
    What connector-types would be needed on the monitor to enable it to be connected to a DVD player?
  2. Binternet
    Binternet
    Oct 30, 2004
    190
    Sunderland/Newcastle
    You only need a TV licence if you use the tuner, if you buy an LCD TV with a tuner just dont plug in the aerial and you will be fine. If the TV licence people come round just tell them where to stick it as what you are doing is 100% legal.
  3. SeanT
    SeanT
    Jan 28, 2005
    6,125
    Coventry
    +371
    I think you'll find you can get screwed if you have any equipment capable of receiving an RF TV signal, including a TV card (although they will have trouble proving this one)
    As students though we used to get letters every term in halls, but as we could refuse to let them in to the building it wasn't really an issue!!!
  4. mariot
    mariot
    yes chaps I'd prefer to play it safe abd not tussle with the beeb, hence my desire to make my AV equipment just a DVD player and, if possible a LCD monitor only -- anyone who has achieved this please enlighten me: suggestions for monitors that will plug stright into a DVD player very much appreciated, since I'm into the dark on this issue.
  5. David Mackenzie
    David Mackenzie
    Aug 28, 2003
    10,213
    Glasgow, UK
    +1,310
    You don't need to bother with the TV license if your equipment isn't capable of picking up UK TV signals.
    For that reason it might be worth your while to investigate buying an American LCD TV. The tuner in this wouldn't pick up UK TV broadcasts at all. Most of the Sharp models seem to operate on the UK voltage and Sharp states them as being PAL compatible - you'd obviously have to make doubly sure before you bought anything though.
    It seems quite drastic, but I think it's robably easier than finding an LCD monitor suitable for "TV like" viewing (IE not a PC monitor with a small viewing angle) without a tuner in it...
