LCD -matrices,differences and what models are placed
Discussion in 'LCD & LED LCD TVs Forum' started by hristoslav2, Oct 31, 2009.
Tags:
Thread Status:
Not open for further replies.
  1. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Hello my Italian friend
    For now, the surest way to understand what type of mold is placed like filming on a white background in macro.
    If i find any information on the issue will publish it in the Italian Forum
    here
    http://www.avmagazine.it/forum/forumdisplay.php?f=72
    Small addition to the description in the sticker for the matrix put in Samsung TVs
    A - AU Optronics (AUO) A-MVA /AC01, AC02, AC03, AC04, AA01, AA02, AA03, AA04, BA01/
    B - Chi Lin Technology (CLT)
    C - Chi Mei Innolux (CMI) /CN01, CN02, BN01, BN02, AO01/
    F - Sharp (UV2A) /FB01/
    E - AU Optronics (AUO) /E01/
    G - AU Optronics (AUO) A-MVA3
    I - LG Display IPS (LGD) S-IPS
    P - Chunghwa Picture Tubes (CPT)
    S - Samsung S-PVA (S-LCD) /SQ01, SQ02, SQ03, SQ04, SS01, SS02, SS03, SS04, SX03/
    Q - IPS Alpha Technology LTD(Hitachi & Panasonic) IPS Alpha / IPS Pro
    Н - Samsung S-PVA (special for 3D)
  2. starfield
    starfield
    Oct 1, 2010
    91
    Have just received a Samsung UE406530 with a version number SS07 any ideas on the panel type and maker?
    Starry
  3. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Hi Starry
    SS07 - type S-PVA from Samsung (S-LCD)
  4. starfield
    starfield
    Oct 1, 2010
    91
    Many thanks for reply, Samsung seem to be using a miriad of codes on there tvs now.
    Starry
  5. devilstrike
    devilstrike
    Jul 24, 2009
    116
    28
    +16
    What sort of panel is this AUO (E01)? is the le37c530.
  6. adtomov
    adtomov
    Oct 19, 2008
    140
    +71
    devilstrike, there is no 3-symbol code on the Samsung TV side sticker. Codes are always 4 symbols in lenght. Would You look at the sticker code again, please?:)
  7. devilstrike
    devilstrike
    Jul 24, 2009
    116
    28
    +16
    My model have no sticker on the side of tv, only on the back.
    E01 also B008 is from the sticker on panel.
  8. adtomov
    adtomov
    Oct 19, 2008
    140
    +71
    Most likely it is A-MVA. But in order to be sure, You can check the information about the panel in the service menu. For accessing the service menu, when the TV set is in stand-by mode, press quickly remote control buttons info-menu-mute-power. At the first page an info about the panel is listed (secton "Type"). For example:
    [​IMG]
    How to decode the "Type" info?
    http://www.avforums.com/forums/10708671-post2.html
    section "SAMSUNG LCD TV"
    Warning! Please do not change anything in the service menu! After getting the panel info, switch the TV set off in order to revert it to the normal user mode!
  9. kurtd
    kurtd
    Nov 10, 2010
    3
    Hi There
    Sorry for a little OT
    [​IMG]
    LG Display( former LG.Philips) LM300WQ3-STA1 used in monitors Dell 3007WFP-HC, HP LP3065, Doublesight DS-305W, Hazro HZ30W.
    is it S-IPS or AS-IPS?
    [​IMG]
    This is pixel structure of H-IPS(or e-IPS, E-IPS, IPS-Pro???) lcd panel module LG Display LM240WU4 used in HP LP2475w, Dell U2410, Eizo CG243, NEC PA241W,
    Philips Brilliance 240PW9EB
    So why do you think that H-IPS is for Low-End aplications mentioned in first page of thread, considering that NEC PA241W and Eizo CG243 are high-end graphics monitors?
    Anyway thanks for great info here:hiya:
  10. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
  11. tavi21s
    tavi21s
    Jan 27, 2011
    3
    Dear all,
    Please be so kind and help me to decide what kind of TV set to buy.
    Taking in consideration that the room I will place the TV is quite small and the distance will be only 1-1.5 m I choose the 32" inch display size.
    Now the problem is that I don't know what model to choose. I understand that there is a very akward lottery almost for any manufactures.
    I was thinking to choose between this models:
    Samsung 32C530 / 550 / 630 / 650
    or
    LG 32LD450 / 465 /750 (the 32LD750 seems quite ok, despite the fact that doesn't have a very good media player integrate it).
    Could you also please let me know main differences/ panels they have. What to look for? Any additional model?
    Thank you very much :),
    Tavi
  12. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Hi tavi21s
    Buy Samsung 32C650
    My colleagues from Bulgaria ,failed to activate the PVR functions in the model 650 / from the service menu / like in model C750.
    Now attempting to overthrow the encryption of the record on a USB stick, so that it can be viewed on a computer.
    Òåëåâèçîðè è ïðîåêòîðè
  13. tavi21s
    tavi21s
    Jan 27, 2011
    3
    Do you know what kind of panel I could get with this monitor? or what could be the best case scenario? :D
  14. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    LE32C650 In this model placed two types of matrices
    SAMSUNG, LTF320HF01 ,32inch, 8bit_16.7M - with better contrast
    AUO, AT315HW04V3,AU31H43, 31.5inch, 8bit+2FRC_1.07billion
  15. tavi21s
    tavi21s
    Jan 27, 2011
    3
    Thank you very much for help.
    Do you know what kind of panel LG 32LD750 has :D also ?
  16. Larus
    Larus
    Jan 6, 2011
    7
    Hello all forum members.
    I'd like to ask you about a specific matrix used in LG LD450/465 series. Namely about one with designation 'Z' as 4th letter in the model code. It's 37" size. I know about W matrices (S-IPS, widely known as good) and D (AUO MVA, rather not recommended, lots of buzzing reports and bad viewing angles), so my question what about Z matrices ? Are there any good ? I just saw boxes so can't say anything about PQ.
    Thanks in advance.
  17. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Hi Larus
    Most likely, the matrix with designation Z is a type of ASV / Sharp & CMI /
    I have no basis for comparison .... therefore would ask all owners of television sets LG - to write their model code
    Code:
    32LG3000 -ZA.AEU[B]S[/B]LWP      SHARP CORPORATION   VA
    37LG5000 -ZA.BEU[b]Q[/b]LJG      LG Display Co.Ltd.    IPS
    32LH3000 -ZA.BEU[b]U[/b]LJP      LG Display Co.Ltd.    IPS  ?
    32LH5000 -ZB.BEU[b]V[/b]LJG      LG Display Co.Ltd.    IPS  ?
    42LH7000 -ZA.BEU[b]V[/b]LJG      LG Display Co.Ltd.    IPS  ?
    32LD350  -ZA.BEU[b]W[/b]LJP      LG Display Co.Ltd.   S-IPS
    42LD465  -ZA.AEU[b]W[/b]LJG      LG Display Co.Ltd.   S-IPS
    32LD550  -ZC.BEU[b]W[/b]LJP      LG Display Co.Ltd.   S-IPS
    42LE5300 -ZA.AEU[b]W[/b]LJG      LG Display Co.Ltd.   S-IPS
    42LE5500 -ZA.BEU[b]W[/b]LJG      LG Display Co.Ltd.   S-IPS
    47LE8500 -ZA.AEU[b]W[/b]L.IG     LG Display Co.Ltd.   S-IPS
    Panasonic New plasma models 2011
    Code:
      model       resolution   panel      filter             contrast      gradation   Hz    MR     processor    DLNA   PVR  Viera Cast  Skype Ready      24p         3D    THX    isf      tuner           Connectors            Design
    TX-P65VT30E   1920 x 1080   G14  Infinity black Pro2  5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    One Sheet of Glass Design
    TX-P55VT30E   1920 x 1080   G14  Infinity black Pro2  5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    One Sheet of Glass Design
    TX-P50VT30E   1920 x 1080   G14  Infinity black Pro2  5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    One Sheet of Glass Design
    TX-P42VT30E   1920 x 1080   G14  Infinity black Pro2  5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    One Sheet of Glass Design
    TX-P50GT30E   1920 x 1080   G14  Infinity black Pro   5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    Flush Design
    TX-P46GT30E   1920 x 1080   G14  Infinity black Pro   5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    Flush Design
    TX-P42GT30E   1920 x 1080   G14  Infinity black Pro   5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes    Yes      Yes        Yes        Smooth Film    Yes   Yes    Yes    DVB-T/C/S   3xUSB  4xHDMI  PC Input    Flush Design
    TX-P50SТ30E   1920 x 1080   G14  Infinity black Pro   5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes     No      Yes        Yes        Smooth Film    Yes    No     No    DVB-T/C     2xUSB  4xHDMI
    TX-P46SТ30E   1920 x 1080   G14  Infinity black Pro   5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes     No      Yes        Yes        Smooth Film    Yes    No     No    DVB-T/C     2xUSB  4xHDMI
    TX-P42SТ30E   1920 x 1080   G14  Infinity black Pro   5000000:1 (Natif)   6144    600   1080   Vreal 3D      Yes     No      Yes        Yes        Smooth Film    Yes    No     No    DVB-T/C     2xUSB  4xHDMI
    TX-P50G30E    1920 x 1080   G14  Infinity black       5000000:1 (Natif)   6144    600   1080   Vreal Live    Yes     No      Yes        No         Smooth Film    Yes   Yes    Yes    DVB-T/C     3xUSB  4xHDMI
    TX-P46G30E    1920 x 1080   G14  Infinity black       5000000:1 (Natif)   6144    600   1080   Vreal Live    Yes     No      Yes        No         Smooth Film    Yes   Yes    Yes    DVB-T/C     3xUSB  4xHDMI
    TX-P42G30E    1920 x 1080   G14  Infinity black       5000000:1 (Natif)   6144    600   1080   Vreal Live    Yes     No      Yes        No         Smooth Film    Yes   Yes    Yes    DVB-T/C     3xUSB  4xHDMI
    TX-P42S30E    1920 x 1080   G14  Infinity black       4000000:1 (Natif)   6144    600   1080   Vreal Live    Yes     No      No         No        Playback Plus   Yes    No     No    DVB-T/C     2xUSB  3xHDMI
    TX-P50U30E    1920 x 1080   G14  Infinity black       2000000:1 (Natif)   6144    600    900   Vreal Plus    Yes     No      No         No        Playback Plus    No    No     No    DVB-T/C            2xHDMI
    TX-P42U30E    1920 x 1080   G14  Infinity black       2000000:1 (Natif)   6144    600    900   Vreal Plus    Yes     No      No         No        Playback Plus    No    No     No    DVB-T/C            2xHDMI
    TX-P50C3E     1024 x 768    G13  Infinity black       2000000:1 (Natif)   4096    600    720   Vreal Plus     No     No      No         No          Playback       No    No     No    DVB-T/C            2xHDMI
    TX-P42C3E     1024 x 768    G13  Infinity black       2000000:1 (Natif)   4096    600    720   Vreal Plus     No     No      No         No          Playback       No    No     No    DVB-T/C            2xHDMI
    MR-Motion Resolution
    Panasonic: Better 3D in the VT30 VT20
    http://translate.google.com/transla...lixeis/6577-panasonic-k-3d--vt30---vt20-.html
  18. adtomov
    adtomov
    Oct 19, 2008
    140
    +71
    kurtd,
    This is an e-IPS subpixel structure.
  19. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    xirtam
    http://forum.ixbt.com/post.cgi?id=attach:62:11088:911:1
    http://forum.ixbt.com/post.cgi?id=attach:62:11088:911:2
    Watch the fourth letter of the product code /42LD750-ZA BPFWLJG/
    XXXRXXX- LG Display Co.Ltd. TN
    XXXWXXX- LG Display Co.Ltd. АS-IPS ?
    XXXYXXX- LG Display Co.Ltd. IPS ?
    XXXUXXX- LG Display Co.Ltd. IPS ?
    XXXPXXX- LG Display Co.Ltd. IPS ?
    XXXQXXX- LG Display Co.Ltd. S-IPS
    XXXVXXX- LG Display Co.Ltd. IPS ?
    XXXGXXX- Chi Mei Optoelectronics Corp. TN
    XXXJXXX- Chi Mei Optoelectronics Corp. S-MVA
    XXXHXXX- Chi Mei Optoelectronics Corp. S-MVA
    XXXDXXX- AU Optronics Corp.
    XXXTXXX- AU Optronics Corp. AMVA
    XXXMXXX- Sharp Corporation
    XXXSXXX- Sharp Corporation
    XXXZXXX- Sharp Corporation ASV
    XXXCXXX- ?
    Code:
    EKHQ    19LD320-ZA    CEKCLA    19LD320    EKHQ   19LD320-ZA    CEUCLA    19LD320
    ERRA    19LD320-ZA    BDRGLBU   19LD320    ERRA   19LD320-ZA    BRUGLBU   19LD320
    EKHQ    19LD320N-ZA   CEUCLA    19LD320N   EKHQ   19LD350-UB    CCCGLA    19LD350
    EKHQ    19LD350-UB    CUSRLA    19LD350    EKHQ   19LD350-UB    CWMGLA    19LD350
    EKHQ    19LD350-UB    CWMSLA    19LD350    EKHQ   19LD350-UB    SUSRLBK   19LD350
    EKHQ    19LD350-UB    CWMRLA    19LD350    EKHQ   19LD350-UB    CUSSLA    19LD350
    EKHQ    19LD350-UB    CUSGLA    19LD350    EKHQ   19LD350-UB    CCCSLA    19LD350
    EKHQ    19LD350-UB    CCCRLA    19LD350    EKHQ   19LD350-ZA    CEKGLA    19LD350
    EKHQ    19LD350-ZA    CEUGLA    19LD350    ERRA   19LD350-ZA    BDRGLBU   19LD350
    ERRA    19LD350-ZA    BRUGLBU   19LD350    EKHQ   19LD350N-ZA   CEUGLA    19LD350N
    EEMA    19LE3300-ZA   BEKWLBP   19LE3300   ERRA   19LE3300-ZA   BRUWLBU   19LE3300
    ERRA    19LE3300-ZA   BDRWLBU   19LE3300   EEMA   19LE3300-ZA   BEUWLBP   19LE3300
    EEMA    19LE3308-ZA   BEUWLBP   19LE3308   EEMA   19LE330N-ZA   BEUWLBP   19LE330N
    ENRS    19LE5300-UE   ACCWLHR   19LE5300   ENRS   19LE5300-UE   AUSWLBR   19LE5300
    ENRS    19LE5300-UE   AUSWLUR   19LE5300   ENRS   19LE5300-UE   AWMWLUR   19LE5300
    ENRS    19LE5300-UE   AWMWLHR   19LE5300   ENRS   19LE5300-UE   AUSWLHR   19LE5300
    EKHQ    22LD320-ZA   CEKCLA   22LD320    ERRA   22LD320-ZA   BRUGLBU   22LD320
    ERRA    22LD320-ZA   BDRGLBU   22LD320    EKHQ   22LD320-ZA   CEUCLA   22LD320
    EKHQ    22LD320N-ZA  CEUCLA   22LD320N   EKHQ   22LD350-UB   CCCGLA   22LD350
    EKHQ    22LD350-UB   CWMGLA   22LD350    EKHQ   22LD350-UB   SUSRLBK   22LD350
    EKHQ    22LD350-UB   CWMRLA   22LD350    EKHQ   22LD350-UB   CUSRLA   22LD350
    EKHQ   22LD350-UB   CCCRLA   22LD350    EKHQ   22LD350-UB   CUSGLA   22LD350
    EKHQ   22LD350-ZA   CEKGLA   22LD350    ERRA   22LD350-ZA   BRUGLBU   22LD350
    EKHQ   22LD350-ZA   CEUGLA   22LD350    EKHQ   22LD350N-ZA  CEUGLA   22LD350N
    EEMA   22LE3300-ZA   BEKWLBP   22LE3300   EEMA   22LE3300-ZA   BEUWLBP   22LE3300
    EEMA   22LE3308-ZA   BEUWLBP   22LE3308   EEMA   22LE330N-ZA   BEUWLBP   22LE330N
    ENRS   22LE5300-UE   ACCWLHR   22LE5300   ENRS   22LE5300-UE   AUSWLHR   22LE5300
    ENRS   22LE5300-UE   AWMWLHR   22LE5300   ENRS   22LE5300-UE   AWMWLUR   22LE5300
    ENRS   22LE5300-UE   AUSWLUR   22LE5300   ENRS   22LE5300-UE   AUSWLBR   22LE5300
    ENRS   22LE5300-UE   ACCWLUR   22LE5300   EKHQ   26LD320-ZA   CEKGLH   26LD320
    EKHQ   26LD320-ZA    CEUGLH   26LD320    EKHQ   26LD320N-ZA  CEUGLH   26LD320N
    EKHQ   26LD350-UB    CCCDLH   26LD350    EKHQ   26LD350-UB   CUSWLH   26LD350
    EKHQ   26LD350-UB    CWMDLH   26LD350    EKHQ   26LD350-UB   CWMWLH   26LD350
    EKHQ   26LD350-UB    SUSDLJK   26LD350    EKHQ   26LD350-UB   CUSDLH   26LD350
    EKHQ   26LD350-UB    CCCWLH   26LD350    EKHQ   26LD350-ZA   CEKDLH   26LD350
    EKHQ   26LD350-ZA    CEUDLH   26LD350    ERRA   26LD350-ZA   BRUDLJU   26LD350
    ERRA   26LD350-ZA    BDRDLJU   26LD350    EKHQ   26LD350N-ZA  CEUDLH   26LD350N
    EEMA   26LE3300-ZA   BEKWLJP   26LE3300   ERRA   26LE3300-ZA   BRUWLJU   26LE3300
    ERRA   26LE3300-ZA   BDRWLJU   26LE3300   EEMA   26LE3300-ZA   BEUWLJP   26LE3300
    EEMA   26LE3308-ZA   BEUWLJP   26LE3308   EEMA   26LE330N-ZA   BEUWLJP   26LE330N
    ENRS   26LE5300-UE   ACCWLUR   26LE5300   ENRS   26LE5300-UE   AUSWLHR   26LE5300
    ENRS   26LE5300-UE   AWMWLHR   26LE5300   ENRS   26LE5300-UE   AWMWLUR   26LE5300
    ENRS   26LE5300-UE   AUSWLUR   26LE5300   ENRS   32LD320-UA   AWMWLHR   32LD320
    ENRS   32LD320-UA    AWMWLJR   32LD320    EKHQ   32LD320-ZA   AFPDLH   32LD320
    ERRA   32LD320-ZA    BDRDLJU   32LD320    ERRA   32LD320-ZA   BRUDLJU   32LD320
    ERRA   32LD320-ZA    ARUDLJU   32LD320    EKHQ   32LD320-ZA   ARUDLH   32LD320
    EKHQ   32LD320-ZA    CEUJLH   32LD320    EKHQ   32LD320-ZA   CEKJLH   32LD320
    EKHQ   32LD350-UB    CCCDLH   32LD350    EKHQ   32LD350-UB   SUSDLJK   32LD350
    EKHQ   32LD350-UB    CWMWLHO   32LD350    EKHQ   32LD350-UB   CWMWLH   32LD350
    EKHQ   32LD350-UB    CWMMLH   32LD350    EKHQ   32LD350-UB   CWMDLH   32LD350
    EKHQ   32LD350-UB    CUSWLHO   32LD350    EKHQ   32LD350-UB   CUSWLH   32LD350
    EKHQ   32LD350-UB    CUSMLH   32LD350    EKHQ   32LD350-UB   CUSDLH   32LD350
    EKHQ   32LD350-UB    CCCMLH   32LD350    EKHQ   32LD350-UB   CCCWLHO   32LD350
    EKHQ   32LD350-UB    CCCWLH   32LD350    EEMA   32LD350-ZA   BEKDLJP   32LD350
    ERRA   32LD350-ZA    BRUDLJU   32LD350    ERRA   32LD350-ZA   BDRDLJU   32LD350
    EEMA   32LD350-ZA    BEKWLJP   32LD350    EEMA   32LD350-ZA   BEUDLJP   32LD350
    EEMA   32LD350-ZA    BEUWLJP   32LD350    EEMA   32LD350C-ZA  BEKWLJP   32LD350C
    EEMA   32LD350C-ZA  BEUWLJP   32LD350C   EEMA   32LD350N-ZA  BEUDLJP   32LD350N
    EEMA   32LD350N-ZA  BEUWLJP   32LD350N   EEMA   32LD351-ZB   BEUWLJP   32LD351
    EEMA   32LD358-ZA    BEUDLJP   32LD358    EEMA   32LD358-ZA   BEUWLJP   32LD358
    EEMA   32LD420-ZA    BEUWLJP   32LD420    ERRA   32LD420-ZA   BRUWLJU   32LD420
    ERRA   32LD420-ZA    BDRWLJU   32LD420    EEMA   32LD420N-ZA  BEUWLJP   32LD420N
    EEMA   32LD428-ZA    BEUWLJP   32LD428    EKHQ   32LD450-UA   CCCDLH   32LD450
    EKHQ   32LD450-UA    CUSDLH   32LD450    EKHQ   32LD450-UA   CUSWLH   32LD450
    EKHQ   32LD450-UA    CCCWLHO   32LD450    EKHQ   32LD450-UA   CCCWLH   32LD450
    EKHQ   32LD450-UA    CUSWLHO   32LD450    EKHQ   32LD450-UA   CWMWLH   32LD450
    EKHQ   32LD450-UA    SUSDLJK   32LD450    EKHQ   32LD450-UA   CWMWLHO   32LD450
    EKHQ   32LD450-UA    CWMDLH   32LD450    EEMA   32LD450-ZA   BEKDLJP   32LD450
    EEMA   32LD450-ZA    BEKWLJP   32LD450    EKHQ   32LD450-ZA   AFPWLH   32LD450
    ERRA   32LD450-ZA    BRUDLJU   32LD450    ERRA   32LD450-ZA   BDRDLJU   32LD450
    EKHQ   32LD450-ZA    AFPDLH   32LD450    EEMA   32LD450-ZA   BEUDLJP   32LD450
    EEMA   32LD450-ZA    BEUWLJP   32LD450    EEMA   32LD450N-ZA  BEUDLJP   32LD450N
    EEMA   32LD450N-ZA  BEUWLJP   32LD450N   EEMA   32LD458-ZA   BEUDLJP   32LD458
    EEMA   32LD458-ZA   BEUWLJP   32LD458    ENRS   32LD520-UA   AUSWLJR   32LD520
    ENRS   32LD520-UA   AWMWLUR   32LD520   ENRS   32LD520-UA   AWMWLHR   32LD520
    ENRS   32LD520-UA   AUSWLUR   32LD520    EKHQ   32LD550-UB   CCCMLH   32LD550
    EKHQ   32LD550-UB   CUSWLH   32LD550    EKHQ   32LD550-UB   CUSWLHO   32LD550
    EKHQ   32LD550-UB   CUSMLH   32LD550   EKHQ   32LD550-UB   CCCWLH   32LD550
    EKHQ   32LD550-UB   CWMWLHO   32LD550    EKHQ   32LD550-UB   SUSMLJK   32LD550
    EEMA   32LD550-ZC   BEKMLJP   32LD550    EEMA   32LD550-ZC   BEKWLJP   32LD550
    EEMA   32LD550-ZC   BEUMLJP   32LD550    EKHQ   32LD550-ZC   AFPWLH   32LD550
    EEMA   32LD550-ZC   BEUWLJP   32LD550    EEMA   32LD550N-ZC  BEUMLJP   32LD550N
    EEMA   32LD551-ZA   BEUMLJP   32LD551    EEMA   32LD551-ZA   BEUWLJP   32LD551
    EEMA   32LD650-ZC   BEUWLJP   32LD650    EEMA   32LD650-ZC   BPFWLJP   32LD650
    ERRA   32LD650-ZC   BRUWLJU   32LD650    ERRA   32LD650-ZC   BDRWLJU   32LD650
    EEMA   32LD650N-ZC  BEUWLJP   32LD650N   EEMA   32LD651-ZB   BEUWLJP   32LD651
    EEMA   32LD680-ZC   BEUWLJP   32LD680   EEMA   32LD690-ZB   BEKWLJP   32LD690
    EEMA   32LD750-ZA   BEUWLJP   32LD750   EKHQ   32LD750-ZA   AFPWLH   32LD750
    EEMA   32LD750N-ZA  BEUWLJP   32LD750N   EEMA   32LD751-ZB   BEUWLJP   32LD751
    EEMA   32LD751-ZB   BPFWLJP   32LD751    EEMA   32LD790-ZA   BEKWLJP   32LD790
    ENRS   32LE5300-UC   ACCDLUR   32LE5300   ENRS   32LE5300-UC   AUSDLUR   32LE5300
    ENRS   32LE5300-UC   AWMDLUR   32LE5300   ENRS   32LE5300-UC   AUSWLUR   32LE5300
    EEMA   32LE5300-ZA   BEKDLJP   32LE5300   EEMA   32LE5300-ZA   BEKWLJP   32LE5300
    EEMA   32LE5300-ZA   BEUDLJP   32LE5300   EEMA   32LE5300-ZA   BEUWLJP   32LE5300
    EEMA   32LE5300-ZA   BVSWLJP   32LE5300   EKHQ   32LE5300-ZA   AFPWLH   32LE5300
    EEMA   32LE5308-ZA   BEUDLJP   32LE5308   EEMA   32LE5308-ZA   BEUWLJP   32LE5308
    EEMA   32LE530N-ZA   BEUWLJP   32LE530N   EEMA   32LE5310-ZB   BEUDLJP   32LE5310
    EEMA   32LE5310-ZB   BEUWLJP   32LE5310   EEMA   32LE5318-ZB   BEUDLJP   32LE5318
    EEMA   32LE5318-ZB   BEUWLJP   32LE5318   ENRS   32LE5400-UC   AUSWLNR   32LE5400
    ENRS   32LE5400-UC   AWMWLJR   32LE5400   ENRS   32LE5400-UC   AWMWLNR   32LE5400
    EEMA   32LE5500-ZA   BEUDLJP   32LE5500   ERRA   32LE5500-ZA   ARUWLJU   32LE5500
    EKHQ   32LE5500-ZA   AFPWLH   32LE5500   EKHQ   32LE5500-ZA   AFPDLH   32LE5500
    EEMA   32LE5500-ZA   BEUWLJP   32LE5500   EEMA   32LE5500-ZA   BVSWLJP   32LE5500
    EEMA   32LE550N-ZA   BEUWLJP   32LE550N   EEMA   32LE5510-ZB   BEUDLJP   32LE5510
    EEMA   32LE5510-ZB   BEUWLJP   32LE5510   EEMA   32LE5510-ZB   BPFDLJP   32LE5510
    EEMA   32LE5510-ZB   BPFWLJP   32LE5510   EEMA   32LE5510-ZB   BVSDLJP   32LE5510
    EEMA   32LE5510-ZB   BVSWLJP   32LE5510   EEMA   32LE5800-ZA   BEUWLJP   32LE5800
    EEMA   32LE5810-ZB   BEUWLJP   32LE5810   EEMA   32LE5900-ZA   BEKWLJP   32LE5900
    EEWR   37LD420-ZA   BEUDLJG   37LD420    EEWR   37LD420-ZA   BEUWLJG   37LD420
    EEWR   37LD420C-ZA  AEUDLJG   37LD420C   EEWR   37LD420N-ZA  BEUDLJG   37LD420N
    EEWR   37LD428-ZA   BEUDLJG   37LD428    EKHQ   37LD450-UA   CCCDLH   37LD450
    EKHQ   37LD450-UA   CUSWLH   37LD450    EKHQ   37LD450-UA   CWMDLH   37LD450
    EKHQ   37LD450-UA   CUSDLH   37LD450    EKHQ   37LD450-UA   CCCWLH   37LD450
    EKHQ   37LD450-UA   CWMWLH   37LD450    EKHQ   37LD450-UA   SUSDLJK   37LD450
    EEWR   37LD450-ZA   AEKDLJG   37LD450    EEWR   37LD450-ZA   AEKWLJG   37LD450
    EEWR   37LD450-ZA   AEUDLJG   37LD450    EKHQ   37LD450-ZA   AFPWLH   37LD450
    ERRA   37LD450-ZA   BRUDLJU   37LD450    EEWR   37LD450-ZA   AEUWLJG   37LD450
    EEWR   37LD450-ZA   BEUDLJG   37LD450    EEWR   37LD450N-ZA  AEUDLJG   37LD450N
    EEWR   37LD450N-ZA  AEUWLJG   37LD450N   EEWR   37LD450N-ZA  BEUWLJG   37LD450N
    EEWR   37LD458-ZA   AEUDLJG   37LD458    EEWR   37LD458-ZA   AEUWLJG   37LD458
    ENRS   37LE5300-UC   AUSDLUR   37LE5300   ENRS   37LE5300-UC   AUSWLUR   37LE5300
    ENRS   37LE5300-UC   AWMWLUR   37LE5300   EEWR   37LE5300-ZA   AEKDLJG   37LE5300
    EEWR   37LE5300-ZA   AEKWLJG   37LE5300   EEWR   37LE5300-ZA   AEUDLJG   37LE5300
    EEWR   37LE5300-ZA   AEUWLJG   37LE5300   EEWR   37LE5300-ZA   AVSDLJG   37LE5300
    EKHQ   37LE5300-ZA   ARUDLH   37LE5300   EKHQ   37LE5300-ZA   AFPWLH   37LE5300
    EEWR   37LE5300-ZA   AVSWLJG   37LE5300   EEWR   37LE5300-ZA   BEKWLJG   37LE5300
    EEWR   37LE5300-ZA   BEUWLJG   37LE5300   EEWR   37LE5300-ZA   BVSWLJG   37LE5300
    EEWR   37LE5308-ZA   AEUDLJG   37LE5308   EEWR   37LE5308-ZA   AEUWLJG   37LE5308
    EEWR   37LE5308-ZA   BEUWLJG   37LE5308   EEWR   37LE530N-ZA   AEUDLJG   37LE530N
    EEWR   37LE530N-ZA   AEUWLJG   37LE530N   EEWR   37LE530N-ZA   BEUWLJG   37LE530N
    EEWR   37LE5310-ZB   AEUDLJG   37LE5310   EEWR   37LE5310-ZB   AEUWLJG   37LE5310
    EEWR   37LE5310-ZB   BEUWLJG   37LE5310   EEWR   37LE5318-ZB   AEUDLJG   37LE5318
    EEWR   37LE5318-ZB   AEUWLJG   37LE5318   EEWR   37LE5318-ZB   BEUWLJG   37LE5318
    EEWR   37LE5500-ZA   BEUDLJG   37LE5500   EEWR   37LE5500-ZA   BEUWLJG   37LE5500
    EEWR   37LE5500-ZA   BVSDLJG   37LE5500   EEWR   37LE5500-ZA   BVSWLJG   37LE5500
    ERRA   37LE5500-ZA   ARUWLJU   37LE5500   EKHQ   37LE5500-ZA   ARUWLH   37LE5500
    EEWR   37LE550N-ZA   BEUDLJG   37LE550N   EEWR   37LE550N-ZA   BEUWLJG   37LE550N
    EEWR   37LE5510-ZB   BEUDLJG   37LE5510   EEWR   37LE5510-ZB   BEUWLJG   37LE5510
    EEWR   37LE5510-ZB   BPFDLJG   37LE5510   EEWR   37LE5510-ZB   BPFWLJG   37LE5510
    EEWR   37LE5510-ZB   BVSDLJG   37LE5510   EEWR   37LE5510-ZB   BVSWLJG   37LE5510
    EEWR   37LE5800-ZA   BEUWLJG   37LE5800   EEWR   37LE5810-ZB   BEUWLJG   37LE5810
    EEWR   37LE5900-ZA   BEKWLJG   37LE5900   ENRS   42LD420-UA   ACCDLJR   42LD420
    ENRS   42LD420-UA    AWMDLFR   42LD420    EEWR   42LD420-ZA   BEUWLJG   42LD420
    EKHQ   42LD420-ZA    ARUWLH   42LD420    EEWR   42LD420C-ZA  AEKWLJG   42LD420C
    EEWR   42LD420C-ZA  AEUWLJG   42LD420C   EEWR   42LD420N-ZA  BEUWLJG   42LD420N
    EEWR   42LD428-ZA    BEUWLJG   42LD428    EKHQ   42LD450-UA   AUSWLH   42LD450
    EKHQ   42LD450-UA    CCCWLH   42LD450    EKHQ   42LD450-UA   CUSDLH   42LD450
    EKHQ   42LD450-UA    CWMWLHO   42LD450    EKHQ   42LD450-UA   CWMWLH   42LD450
    EKHQ   42LD450-UA    CWMMLH   42LD450    EKHQ   42LD450-UA   CWMJLH   42LD450
    EKHQ   42LD450-UA    CWMDLH   42LD450    EKHQ   42LD450-UA   CUSWLHO   42LD450
    EKHQ   42LD450-UA    CUSWLH   42LD450    EKHQ   42LD450-UA   CUSMLH   42LD450
    EKHQ   42LD450-UA    CUSJLH   42LD450    EKHQ   42LD450-UA   SUSWLJK   42LD450
    EKHQ   42LD450-UA    CCCWLHO   42LD450    EKHQ   42LD450-UA   CCCMLH   42LD450
    EKHQ   42LD450-UA    CCCDLH   42LD450    EKHQ   42LD450-UA   CCCJLH   42LD450
    EEWR   42LD450-ZA    AEKDLJG   42LD450    EEWR   42LD450-ZA   AEKWLJG   42LD450
    EEWR   42LD450-ZA    AEUDLJG   42LD450    EEWR   42LD450-ZA   AEUWLJG   42LD450
    ERRA   42LD450-ZA    BRUWLJU   42LD450    ERRA   42LD450-ZA   BDRWLJU   42LD450
    EKHQ   42LD450-ZA    ARUWLH   42LD450    EKHQ   42LD450-ZA   AFPWLH   42LD450
    EKHQ   42LD450-ZA    AEUWLH   42LD450    EEWR   42LD450-ZA   BEUWLJG   42LD450
    EEWR   42LD450N-ZA  AEUDLJG   42LD450N   EEWR   42LD450N-ZA  AEUWLJG   42LD450N
    EEWR   42LD458-ZA    AEUWLJG   42LD458    ENRS   42LD520-UA   ACCWLJR   42LD520
  20. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Code:
    enrs   42ld520-ua    auswlur   42ld520    enrs   42ld520-ua   awmwljr   42ld520
    enrs   42ld520-ua    awmwlnr   42ld520    enrs   42ld520-ua   auswlnr   42ld520
    enrs   42ld520-ua    auswljr   42ld520    ekhq   42ld550-ub   cccjlh   42ld550
    ekhq   42ld550-ub    suswljk   42ld550    ekhq   42ld550-ub   cwmwlho   42ld550
    ekhq   42ld550-ub    cwmwlh   42ld550    ekhq   42ld550-ub   cwmjlh   42ld550
    ekhq   42ld550-ub    cuswlho   42ld550    ekhq   42ld550-ub   cccwlho   42ld550
    ekhq   42ld550-ub    cusjlh   42ld550    ekhq   42ld550-ub   cccwlh   42ld550
    ekhq   42ld550-ub    cuswlh   42ld550    eewr   42ld550-zc   aekwljg   42ld550
    eewr   42ld550-zc    aeuwljg   42ld550    eewr   42ld550-zc   bekwljg   42ld550
    eewr   42ld550-zc    beuwljg   42ld550    erra   42ld550-zc   bruwlju   42ld550
    erra   42ld550-zc    bdrwlju   42ld550    ekhq   42ld550-zc   afpwlh   42ld550
    eewr   42ld550n-zc  aeuwljg   42ld550n   eewr   42ld550n-zc  beuwljg   42ld550n
    eewr   42ld551-za   aeuwljg   42ld551    eewr   42ld551-za   beuwljg   42ld551
    enrs   42ld630-uc   accwlur   42ld630    enrs   42ld630-uc   awmwlur   42ld630
    eewr   42ld650-zc   beuwljg   42ld650    eewr   42ld650-zc   bpfwljg   42ld650
    erra   42ld650-zc   bruwlju   42ld650    erra   42ld650-zc   bdrwlju   42ld650
    ekhq   42ld650-zc   afpwlh   42ld650    eewr   42ld650n-zc  beuwljg   42ld650n
    eewr   42ld651-zb   beuwljg   42ld651    eewr   42ld680-zc   beuwljg   42ld680
    eewr   42ld690-zb   bekwljg   42ld690    eewr   42ld690-zc   bekwljg   42ld690
    eewr   42ld750-za   beuwljg   42ld750    erra   42ld750-za   bdrwlju   42ld750
    erra   42ld750-za   bruwlju   42ld750    ekhq   42ld750-za   afpwlh   42ld750
    eewr   42ld750-za   bpfwljg   42ld750    eewr   42ld750n-za  beuwljg   42ld750n
    eewr   42ld751-zb   beuwljg   42ld751    eewr   42ld751-zb   bpfwljg   42ld751
    eewr   42ld790-za   bekwljg   42ld790    enrs   42le5300-uc   accwlur   42le5300
    enrs   42le5300-uc   awmwlur   42le5300   eewr   42le5300-za   aekdljg   42le5300
    eewr   42le5300-za   aekwljg   42le5300   eewr   42le5300-za   aeudljg   42le5300
    eewr   42le5300-za   aeuwljg   42le5300   eewr   42le5300-za   avsdljg   42le5300
    eewr   42le5300-za   avswljg   42le5300   eewr   42le5300-za   bekwljg   42le5300
    ekhq   42le5300-za   afpwlh   42le5300   ekhq   42le5300-za   aeuwlh   42le5300
    eewr   42le5300-za   beuwljg   42le5300   eewr   42le5300-za   bvswljg   42le5300
    eewr   42le5308-za   aeudljg   42le5308   eewr   42le5308-za   aeuwljg   42le5308
    eewr   42le5308-za   beuwljg   42le5308   eewr   42le530n-za   aeudljg   42le530n
    eewr   42le530n-za   aeuwljg   42le530n   eewr   42le530n-za   beuwljg   42le530n
    eewr   42le5310-zb   aeudljg   42le5310   eewr   42le5310-zb   aeuwljg   42le5310
    eewr   42le5310-zb   beuwljg   42le5310   eewr   42le5318-zb   aeudljg   42le5318
    eewr   42le5318-zb   aeuwljg   42le5318   eewr   42le5318-zb   beuwljg   42le5318
    enrs   42le5400-uc   accdlnr   42le5400   enrs   42le5400-uc   auswlnr   42le5400
    enrs   42le5400-uc   awmwljr   42le5400   enrs   42le5400-uc   awmwlhr   42le5400
    enrs   42le5400-uc   awmdlnr   42le5400   enrs   42le5400-uc   auswlur   42le5400
    enrs   42le5400-uc   auswljr   42le5400   enrs   42le5400-uc   accwlhr   42le5400
    enrs   42le5400-uc   ausdlhr   42le5400   enrs   42le5400-uc   ausdlnr   42le5400
    enrs   42le5400-uc   auswlhr   42le5400   enrs   42le5400-uc   accwljr   42le5400
    enrs   42le5500-ua   accwljr   42le5500   enrs   42le5500-ua   auswljr   42le5500
    enrs   42le5500-ua   auswlhr   42le5500   enrs   42le5500-ua   auswlfr   42le5500
    eewr   42le5500-za   beuwljg   42le5500   eewr   42le5500-za   bpfwljg   42le5500
    erra   42le5500-za   aruwlju   42le5500   eewr   42le5500-za   bvswljg   42le5500
    eewr   42le550n-za   beuwljg   42le550n   eewr   42le5510-zb   beuwljg   42le5510
    eewr   42le5510-zb   bpfwljg   42le5510   eewr   42le5510-zb   bvswljg   42le5510
    eewr   42le5800-za   beuwljg   42le5800   eewr   42le5810-zb   beuwljg   42le5810
    eewr   42le5900-za   bekwljg   42le5900   enrs   42le7300-ua   accwlur   42le7300
    enrs   42le7300-ua   auswlur   42le7300   enrs   42le7500-uc   auswljr   42le7500
    enrs   42le7500-uc   awmwlfr   42le7500   eewr   42le8500-za   beuwljg   42le8500
    eewr   42le8500-za   bpfwljg   42le8500   eewr   42le8500-za   bvswljg   42le8500
    eewr   42le850n-za   beuwljg   42le850n   eewr   42le8800-za   beuwljg   42le8800
    eewr   42le8900-za   bekwljg   42le8900   enrs   46ld550-ub   accmlfr   46ld550
    enrs   46ld550-ub   ausmlfr   46ld550    enrs   46ld550-ub   ausmlur   46ld550
    enrs   46ld550-ub   awmmljr   46ld550    enrs   46ld550-ub   awmmlfr   46ld550
    enrs   46ld550-ub   ausmljr   46ld550    enrs   46ld550-ub   accmlur   46ld550
    enrs   46ld550-ub   accmljr   46ld550    eewr   46ld550-zc   aeumljg   46ld550
    eewr   46ld550-zc   bekmljg   46ld550    eewr   46ld550-zc   beumljg   46ld550
    eewr   46ld550n-zc  aeumljg   46ld550n   eewr   46ld550n-zc  beumljg   46ld550n
    eewr   46ld551-za   aeumljg   46ld551    eewr   46ld551-za   beumljg   46ld551
    enrs   47ld420-ua   awmwljr   47ld420    eewr   47ld420-za   beuwljg   47ld420
    ekhq   47ld420-za   afpwlh   47ld420    erra   47ld420-za   bruwlju   47ld420
    erra   47ld420-za   bdrwlju   47ld420    eewr   47ld420c-za  aeuwljg   47ld420c
    eewr   47ld420n-za  beuwljg   47ld420n   enrs   47ld450-ua   accwlfr   47ld450
    enrs   47ld450-ua   accwljr   47ld450    enrs   47ld450-ua   accwlhr   47ld450
    enrs   47ld450-ua   auswlfr   47ld450    enrs   47ld450-ua   auswlur   47ld450
    enrs   47ld450-ua   awmwljr   47ld450    enrs   47ld450-ua   awmwlfr   47ld450
    enrs   47ld450-ua   auswljr   47ld450    enrs   47ld450-ua   accwlvr   47ld450
    enrs   47ld450-ua   accwlur   47ld450    eewr   47ld450-za   aekwljg   47ld450
    eewr   47ld450-za   aeuwljg   47ld450    erra   47ld450-za   bruwlju   47ld450
    erra   47ld450-za   bdrwlju   47ld450    ekhq   47ld450-za   afpwlh   47ld450
    eewr   47ld450-za   beuwljg   47ld450    ekhq   47ld450-za   agswlh   47ld450
    eewr   47ld450n-za  aeuwljg   47ld450n   eewr   47ld458-za   aeuwljg   47ld458
    enrs   47ld520-ua   accwljr   47ld520    enrs   47ld520-ua   awmwlur   47ld520
    enrs   47ld520-ua   awmwljr   47ld520    enrs   47ld520-ua   accwlur   47ld520
    enrs   47ld520-ua   auswljr   47ld520    enrs   47ld520-ua   auswlur   47ld520
    enrs   47ld630-uc   accwlur   47ld630    enrs   47ld630-uc   awmwlur   47ld630
    enrs   47ld650-ua   awmwlfr   47ld650    enrs   47ld650-ua   awmwljr   47ld650
    eewr   47ld650-zc   beuwljg   47ld650    eewr   47ld650-zc   bpfwljg   47ld650
    eewr   47ld650n-zc  beuwljg   47ld650n   eewr   47ld651-zb   beuwljg   47ld651
    eewr   47ld680-zc   beuwljg   47ld680    eewr   47ld690-zb   bekwljg   47ld690
    eewr   47ld750-za   beuwljg   47ld750    erra   47ld750-za   bruwlju   47ld750
    erra   47ld750-za   bdrwlju   47ld750    eewr   47ld750-za   bpfwljg   47ld750
    eewr   47ld750n-za  beuwljg   47ld750n   eewr   47ld751-zb   beuwljg   47ld751
    eewr   47ld751-zb   bpfwljg   47ld751    eewr   47ld790-za   bekwljg   47ld790
    eewr   47ld920-za   bekvljg   47ld920    eewr   47ld920-za   beuvljg   47ld920
    enrs   47le5300-uc   accwljr   47le5300   enrs   47le5300-uc   accwlur   47le5300
    enrs   47le5300-uc   awmwlur   47le5300   eewr   47le5300-za   aekwljg   47le5300
    eewr   47le5300-za   aeuwljg   47le5300   eewr   47le5300-za   avswljg   47le5300
    eewr   47le5300-za   bekwljg   47le5300   eewr   47le5300-za   beuwljg   47le5300
    ekhq   47le5300-za   aruwlh   47le5300   ekhq   47le5300-za   afpwlh   47le5300
    eewr   47le5300-za   bvswljg   47le5300   eewr   47le5308-za   aeuwljg   47le5308
    eewr   47le5308-za   beuwljg   47le5308   eewr   47le530n-za   aeuwljg   47le530n
    eewr   47le530n-za   beuwljg   47le530n   eewr   47le5310-zb   aeuwljg   47le5310
    eewr   47le5310-zb   beuwljg   47le5310   eewr   47le5318-zb   beuwljg   47le5318
    enrs   47le5400-uc   auswlhr   47le5400   enrs   47le5400-uc   awmwlhr   47le5400
    enrs   47le5400-uc   auswljr   47le5400   enrs   47le5400-uc   awmwljr   47le5400
    enrs   47le5500-ua   accwljr   47le5500   enrs   47le5500-ua   auswljr   47le5500
    enrs   47le5500-ua   auswlur   47le5500   enrs   47le5500-ua   awmwljr   47le5500
    eewr   47le5500-za   aeuwljg   47le5500   eewr   47le5500-za   avswljg   47le5500
    eewr   47le5500-za   beuwljg   47le5500   eewr   47le5500-za   bpfwljg   47le5500
    ekhq   47le5500-za   aruwlh   47le5500   ekhq   47le5500-za   afpwlh   47le5500
    eewr   47le5500-za   bvswljg   47le5500   eewr   47le550n-za   aeuwljg   47le550n
    eewr   47le550n-za   beuwljg   47le550n   eewr   47le5510-zb   aeuwljg   47le5510
    eewr   47le5510-zb   avswljg   47le5510   eewr   47le5510-zb   beuwljg   47le5510
    eewr   47le5510-zb   bpfwljg   47le5510   eewr   47le5510-zb   bvswljg   47le5510
    eewr   47le5800-za   beuwljg   47le5800   eewr   47le5810-zb   beuwljg   47le5810
    eewr   47le5900-za   bekwljg   47le5900   enrs   47le7300-ua   accwlur   47le7300
    enrs   47le7300-ua   auswljr   47le7300   enrs   47le7300-ua   auswlur   47le7300
    ekhq   47le7500-ta   zmdwljk   47le7500   ekhq   47le8500-ua   auswlh   47le8500
    enrs   47le8500-ua   awmwljr   47le8500   enrs   47le8500-ua   awmwlnr   47le8500
    enrs   47le8500-ua   auswlur   47le8500   enrs   47le8500-ua   accwljr   47le8500
    enrs   47le8500-ua   auswlnr   47le8500   enrs   47le8500-ua   auswljr   47le8500
    eewr   47le8500-za   beuwljg   47le8500   eewr   47le8500-za   bpfwljg   47le8500
    eewr   47le8500-za   bvswljg   47le8500   eewr   47le850n-za   beuwljg   47le850n
    eewr   47le8800-za   beuwljg   47le8800   eewr   47le8900-za   bekwljg   47le8900
    enrs   52ld550-ub   accmlfr   52ld550    enrs   52ld550-ub   ausmlfr   52ld550
    enrs   52ld550-ub   ausmlur   52ld550    enrs   52ld550-ub   awmmlfr   52ld550
    eewr   52ld550-zc   bekmljg   52ld550    eewr   52ld550-zc   beumljg   52ld550
    erra   52ld550-zc   brumlju   52ld550    eewr   52ld550n-zc  beumljg   52ld550n
    eewr   52ld551-za   beumljg   52ld551    enrs   55ld520-ua   accdljr   55ld520
    enrs   55ld520-ua   ausdlfr   55ld520    enrs   55ld520-ua   ausdlhr   55ld520
    enrs   55ld520-ua   accwlfr   55ld520    enrs   55ld520-ua   accdlur   55ld520
    enrs   55ld520-ua   ausdljr   55ld520    enrs   55ld520-ua   auswlfr   55ld520
    enrs   55ld520-ua   auswlur   55ld520    enrs   55ld520-ua   ausdlur   55ld520
    enrs   55ld630-uc   accwlur   55ld630    enrs   55ld630-uc   awmwlhr   55ld630
    enrs   55ld630-uc   awmwlur   55ld630    enrs   55ld650-ua   accwljr   55ld650
    enrs   55ld650-ua   accwlur   55ld650    enrs   55ld650-ua   auswljr   55ld650
    enrs   55ld650-ua   awmwljr   55ld650    enrs   55ld650-ua   auswlur   55ld650
    enrs   55ld650-ua   auswlfr   55ld650    eewr   55ld650-zc   beuwljg   55ld650
    eewr   55ld650-zc   bpfwljg   55ld650    eewr   55ld650n-zc  beuwljg   55ld650n
    eewr   55ld651-zb   beuwljg   55ld651    eewr   55ld680-zc   beuwljg   55ld680
    eewr   55ld690-zb   bekwljg   55ld690    enrs   55le5300-uc   accwlur   55le5300
    eewr   55le5300-za   aekwljg   55le5300   ekhq   55le5300-za   aruwlh   55le5300
    ekhq   55le5300-za   afpwlh   55le5300   eewr   55le5300-za   aeuwljg   55le5300
    eewr   55le5300-za   avswljg   55le5300   eewr   55le5300-za   beuwljg   55le5300
    eewr   55le5300-za   bvswljg   55le5300   eewr   55le5308-za   aeuwljg   55le5308
    eewr   55le5308-za   beuwljg   55le5308   eewr   55le530n-za   aeuwljg   55le530n
    eewr   55le530n-za   beuwljg   55le530n   eewr   55le5310-zb   aeuwljg   55le5310
    eewr   55le5310-zb   beuwljg   55le5310   enrs   55le5400-uc   accwlhr   55le5400
    enrs   55le5400-uc   auswljr   55le5400   enrs   55le5400-uc   awmwlhr   55le5400
    enrs   55le5400-uc   awmwlnr   55le5400   enrs   55le5400-uc   awmwljr   55le5400
    enrs   55le5400-uc   auswlnr   55le5400   enrs   55le5400-uc   auswlhr   55le5400
    enrs   55le5400-uc   accwljr   55le5400   ekhq   55le5500-ua   auswlh   55le5500
    enrs   55le5500-ua   awmwljr   55le5500   enrs   55le5500-ua   auswljr   55le5500
    enrs   55le5500-ua   accwljr   55le5500   enrs   55le5500-ua   auswlfr   55le5500
    eewr   55le5500-za   beuwljg   55le5500   ekhq   55le5500-za   afpwlh   55le5500
    ekhq   55le5500-za   aruwlh   55le5500   ekhq   55le5500-za   agswlh   55le5500
    eewr   55le5500-za   bvswljg   55le5500   eewr   55le550n-za   beuwljg   55le550n
    eewr   55le5510-zb   beuwljg   55le5510   eewr   55le5800-za   beuwljg   55le5800
    enrs   55le7500-uc   auswljr   55le7500   enrs   55le8500-ua   accwljr   55le8500
    enrs   55le8500-ua   auswljr   55le8500   enrs   55le8500-ua   auswlnr   55le8500
    enrs   55le8500-ua   awmwlnr   55le8500   enrs   55le8500-ua   auswlur   55le8500
    enrs   55le8500-ua   accwlnr   55le8500   enrs   55le8500-ua   accwlur   55le8500
    eewr   55le8500-za   beuwljg   55le8500   eewr   55le8500-za   bpfwljg   55le8500
    eewr   55le8500-za   bvswljg   55le8500   eewr   55le850n-za   beuwljg   55le850n
    eewr   55le8800-za   beuwljg   55le8800   enrs   60ld550-ub   ausmlfr   60ld550
    enrs   60ld550-ub   ausmlur   60ld550    enrs   60ld550-ub   awmmlfr   60ld550
    enrs   60ld550-ub   ausmljr   60ld550    eewr   60ld550-zc   aekmljg   60ld550
    eewr   60ld550-zc   aeumljg   60ld550    ekhq   60ld550-zc   arumlh   60ld550
    eewr   60ld550-zc   bekmljg   60ld550    eewr   60ld550-zc   beumljg   60ld550
    eewr   60ld550n-zc  aeumljg   60ld550n   eewr   60ld558-zc   aeumljg   60ld558
    eewr   60ld558-zc   beumljg   60ld558
  21. kurtd
    kurtd
    Nov 10, 2010
    3
    Sorry for another little OT
    To Hristoslav2
    Dont you know what image processing electronics (LCD monitor/ LCD TV Controllers) are used in Eizo monitors?
    I know about one, its STMicroelectronics (former/purchased GENESIS Display perfection), but another or some sources?
    Thanks in advance
  22. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Hi kurtd
    Unfortunately I do not know. Let someone else who knows something about it to respond.
  23. xirtam
    xirtam
    Jan 14, 2011
    thanks a lot hristoslav2
  24. orientalmed
    orientalmed
    Dec 15, 2010
    13
    Iasi, Romania
    Greetings from Romania ..
    I just bought 42ld650. Now it is on my workplace. Monday I will check the label to see the panel. Till then I know that when I see the display in a large angle the black became ...violet/reddish.
    like here http://lcdtech.no-ip.info/images/lcd.faq.05.jpg
    and here :http://www.hdtv.ru/uploads/faq/1213185847_ips.jpg
    It is true that it is an IPS? What revision I do not know...I will make an macro at the panel. it is assembled in Poland in December 2010.
    QUESTION: why in USA ld650 is with 240hz, and in Europe the same model has only 100 hz? It is not about PAL, and SECAM I know the differences, but it is almost double the frequencies in USA...
    Regards to all
  25. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    Hi orientalmed
    This is because:
    the frequency of the grid in Europe - 50Hz./220V/ - TV is operated in 50 frames per second
    the frequency of the grid in U.S. - 60Hz/110V/ - TV is operated in 60 frames per second
    in Europe -
    2x50Hz = 100Hz /one full frame and a blank frame
    4x50Hz = 200Hz / one full frame and three empty frames
    4x50Hz /200Hz/ + scanning backlight /x2/ = 400Hz / one full frame and seven empty frames
    400Hz = 200Hz + Scanning Backlight
    in USA -
    2x60Hz = 120Hz /one full frame and a blank frame
    4x60Hz = 240Hz / one full frame and three empty frames
    4x60Hz /240Hz/+ scanning backlight /x2/ = 480Hz / one full frame and seven empty frames
    480Hz = 240Hz + Scanning Backlight
    http://www.youtube.com/watch?v=-apG9SaJtKU
    http://www2.vieraexperience.com/html/en_GB/superior-picture/moving-picture-performance/introduction
    http://en.wikipedia.org/wiki/Motion_interpolation
  26. orientalmed
    orientalmed
    Dec 15, 2010
    13
    Iasi, Romania
    I see ..thank you , but
    I do not understand all :
    un Europe I have for ld650 2*50=100hz
    in USA they present this TV as 240hz (4*60).. not 120hz (2*60hz) ( 4*60hz versus 2*50hz), ( 4 versus 2)
    Is double..
    What I am missing?
    By the way..
    my tv is :
    ZC.AEUWLJG
    seria: 009WRBMOD573
    W It is an AS-IPS panel (W) or S-ips?
    I will take a picture of the panel but I do not have for the moment the foto camera.
  27. adtomov
    adtomov
    Oct 19, 2008
    140
    +71
    Hi, orientalmed,
    Currently, it is an AS-IPS panel.
  28. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
  29. orientalmed
    orientalmed
    Dec 15, 2010
    13
    Iasi, Romania
    I have one short question...regarding the lcd display ( I will deleted if there is the wrong place for the post)but you guys are masters in LCD panels.
    I do not know if my TV is damaged or not:
    I connect the PC to TV ( HDMI)1920*1080(60 hz)and all lines or black pixels are perfect when are on the white background., But when the lines are over a red background the black pixels of the lines are slightly blurred..Also the black pixels over red zones are HORIZONTALLY blurred..
    (the dots in the picture are 1px x 1px square with red and white background)..
    I need an opinion because i must decide if tomorrow morning I will return back to the store or not. The picture of the TV is excellent except it is hard to work in vectorial software as Illustrator and Corel because of those blurring phenomena of the vertical lines.
    I tested with 2 video cards and 2 hdmi cables with all the possible setting available..
    [​IMG]
    This is the look of my display in Illustrator...annoying..:
    [​IMG]
    Thankyou
  30. hristoslav2
    hristoslav2
    Jul 6, 2009
    609
    43
    Varna Bulgaria
    +206
    orientalmed
    This is normal - the reason lies in the work of colored filters.
Thread Status:
