LCD - is it the obvious choice
Discussion in 'Desktop & Laptop Computers Forum' started by Nicky, Nov 8, 2004.
  1. Nicky
    Nicky
    Nov 5, 2003
    179
    +5
    Hi, I'm looking at builidng/buying a HTPC but I want to sort out the screen first. The system will get used for a combination of home theatre and games playing. A PJ is out due to room size issues so the choice is basically LCD or plasma. However pressumably the PC will be much happier with a nice high res (say 1280x768 or whatever is the standard) WS LCD than it will be with a 800x480 plasma. I don't really fancy the big bucks for a high res plasma and even these seem to be quite a pain to get the scaling ratios correct on. So LCD seems a no brainer. Is this right?
    Nick
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    It sounds like you've made a good case for an LCD .. just make sure if you buy one that it accepts PC input at its' native resolution, not all do, often the cheaper ones.
  3. SeaneyC
    SeaneyC
    Jul 26, 2002
    2,031
    48
    Reading, Berkshire
    +54
    the 30" DabsValue Medion LCD seems to be a pretty good screen for under £1000, try a search in the LCD screens forum, there were a lot of people talking about it. I was thinking about getting one myself, but i decided to get a projector instead.
