LCD interferes with remote controls?
Discussion in 'LCD & LED LCD TVs Forum' started by NedK, Sep 14, 2007.
Tags:
  1. NedK
    NedK
    Jun 5, 2002
    97
    11
    Bracknell, Berks
    +13
    I've had my LCD TV for a few days and I noticed earlier that the remote for my amp would not work from the usual range. I had to get quite close to the amp to get it to work. After I turned the TV off however, it worked fine at the normal range.
    Is this a common problem, and is there anything I can do about it?
  2. bossc@
    [email protected]
    Dec 20, 2001
    1,210
    +285
    It can be with plasmas definitely, due to the amount of IR the panel throws out (My Panny PW5 is a bugger for interfering) but I didn't think it was an issue for LCDs, I certainly haven't noticed it with my LCD.
  3. RockySpieler
    RockySpieler
    May 23, 2005
    1,661
    Snaking the Lineup
    +115
    I had issues with my TEVION and my Telewest STB, but my Toshiba 42X3030D is fine.
    Does your TV have active backlight control?
    Try turning it off, I recall some Sharp TV's with this feature were blocking IR signals.
    If I remember rightly they had a work-around solution of covering the sensor with stickly tape.
  4. NedK
    NedK
    Jun 5, 2002
    97
    11
    Bracknell, Berks
    +13
    The TV is a Samsung LE40F86. I have the backlight set to 1 out of 10 so it's only just on, but it still interferes with the remotes for my V+ box and amplifier.
    I'm just hoping that it will get better when I get a proper stand for the TV which will make it a bit higher up.
