LCD Input & Converters
Discussion in 'LCD & LED LCD TVs Forum' started by milanlad, Sep 1, 2003.
Tags:
  1. milanlad
    milanlad
    Sep 10, 2002
    359
    West Yorkshire, UK
    If I have an LCD display which was bought for use with a PC, what type of converter do I require if I want to play a composite video (or an s-video or Pal RGB) signal through the monitor?
    If I buy a standard LCD TV (with or without a tuner) can I put a PC display output through the LCD TV? I pressume some form of converter would be needed.
    Thanks in advance
  2. NonPayingMember
    NonPayingMember
    Previously Liam @ Prog AV
    Oct 18, 2002
    8,523
    Kent
    +830
    Standard LCD TVs tend to have PC inputs too, so it's just a case of changing channel to use the PC, then back again to watch TV.
    However, a converter like the JS Technology or Keene Syncblaster ones will not allow video signals to be displayed on your standard monitor. What you need is a scaler that can alter the video signal to a high resolution one for your monitor.
    The ProV+ is perfect in this scenario as it has TV tuner, remote, video inputs plus a socket for the PC so you can select PC by remote or have the PC work with the ProV off.
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,152
    Cumbria
    +1,276
    you also need to confirm that the 'converter' matches the capabilities of the display panel, many older ones do not. Look for the 50 Hz capabilities
  4. dejongj
    dejongj
    And of-course that the outputs as closely match the native resolution of the LCD panel. For example if you have a widescreen LCD panel, you will find that the likes of an PRO-V only support 4:3 resolutions.
    In my knowledge the cheapest option will be to let your PC do the scaling in order to get a good picture quality and pixel-exact information.
    The change left from buying a computer LCD panel should be plenty to upgrade your PC to a scaler PC (dscale for example), or even build one. A lot of the LCD-TV have 'inferior' resolutions as the resolution is build for (mainly) US TV frame size 640x480. Whilst PAL for example is 768x576. So you need at the very least an 800x600 native resolution in order to display the PAL framesize without any scaling....
    Hope this helped...
