LCD + HTPC all in one system
Discussion in 'Home Entertainment Computers' started by Tom D., Sep 1, 2005.
  1. Tom D.
    Tom D.
    I am looking for a LCD PC with Media Center system setup. Because of lack of space, a LCD + HTPC all in one system might work well for me in this case. Can someone recommend a good system? A 27inch LCD screen is the size I am looking for.
  2. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi Tom,
    All I can say is yes, they do exist but I can't for the life of me remember who does them. maybe someone else can help on this one. A friend of mine who works for M$ says they were also looking into it.
    Richie.
  3. stuartmc
    stuartmc
    Oct 20, 2004
    203
    16
    Reading
    Elonex do a 32" version called the Lumina
  4. Tom D.
    Tom D.
  5. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Information I can give you is that it's not HDTV ready in terms of the UK. There isn't a DVI or HDMI conenction so linking up SKY Hi Def or BluRay/HD-DVD player would be a nightmare unless you want to crack open the LCD and change the DVD drive.
    Richie.
  6. tommyfly
    tommyfly
    May 13, 2005
    17
    3
    London
