LCD for testing kit?
Discussion in 'LCD & LED LCD TVs' started by Nic Rhodes, Jul 20, 2005.
  1. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    I need a LCD widescreen 'tv' for testing purposes but budget is not huge (say £700)
    It needs to be able to do HDMI / DVI with HDCP
    VGA input would be great and would allow it's use for PC (1:1 prefered) which would allow less kit in the room
    SVHS
    Component with 480i and p (60Hz), 567i and p (60Hz), 720p@50 and 60 Hz and 1080i@50 and 60 Hz
    anything else a bonus (like SCART)
    Picture quality is not the primary reason, nor tv reception, but will be used for evaluating kit specifications, therefore a digital input (DVI / HDMI) that allows many different standards (PC / video) would be highly advantageous. Don't want any glaring faults however.
    Size between 20 to 26 inch with typical resolution of 1366 x 768 would be fine.
    Any ideas?, I have seen a few close, but often they trip up with the odd specification....
  2. benwong
    benwong
    Samsung LE-26R41BDX or LE-26R51BDX?
    Supposed to be quite good. Haven't seen it myself though..
    Ben
  3. Nic Rhodes
    Nic Rhodes
    Mar 23, 2001
    17,133
    Cumbria
    +1,277
    yes those are the ones I have been looking at but the 32 thread is just plain silly now :(
