LCD for PC??
Discussion in 'LCD & LED LCD TVs Forum' started by Theman7, Jul 23, 2005.
Tags:
  1. Theman7
    Theman7
    :lease:
    Ive got about a grand to spend, I want to put all my toys (ie PC and PS2) through one tv. I assumed LCD would be best (although I'm a bit unsure about some plasmas)
    I was thinking of the philips 32PF5520D.
    Can anyone see any problems with conecting a PC so that I can use wireless keyboard and mouse and sit on my sofa using it?
    Is this sort of LCD best for my needs? I picked that one, because the resolution was quite high.
    Thanks in advance!
  2. probedb
    probedb
    Aug 20, 2003
    2,654
    Sheffield
    +180
    If it's got a DVI, HDMI, VGA or Component in then you can feed a PC into it. I think VGA is probably the simplest (correct me if I'm wrong but people seem to have issues with DVI) and would just be a question of selecting the 1:1 resolution to the displays screen res. DVI and HDMI (with DVI-HDMI adaptor) should be the same, then most gfx cards nowadays have a component adaptor which can output 720p or 1080i which your screen should accept.
    A post in the HTPC forum might get better answers? HTH :)
  3. peahead
    peahead
    Dec 14, 2002
    3,003
    St.helens
    +385
