LCD for PC use - Samsung 32A558 vs 32A656?
Discussion in 'What Is The Best TV For You?' started by singh_uk, Feb 8, 2009.
  1. singh_uk
    singh_uk
    Feb 8, 2009
    12
    Hello
    I am looking to get a 32" 1080p LCD TV for PC use - mixture of browsing, films and gaming.
    My initial choice was the Sony 32W4000 however this seems to have been discontinued and is difficult to find anywhere for a reasonable price.
    I am now stuck between the Samsung 32A558 and 32A656 - I will not be using the sound on the TV as I have a seperate speaker set up - could anyone enlighten me to the real differences between the two panels? As far as I can see the 6 series has an extra HDMI connector and a rose black finish (which I dont really like!) so is there any other reason I should not go for the 5 series? Will motion etc in gaming be worse on the 558?
    Also any other suggestions for 32" 1080p screens suitable for PC use would be appreciated.
  2. nenito2k
    nenito2k
    Aug 13, 2008
    1,384
    +119
    5 has DNIE plus engine and 6 has DNIE PRo engine, its not the same.
    the engine is responsible for black, motion and colours....is that a good answer for you?
