LCD For Freeview
Discussion in 'LCD & LED LCD TVs' started by paulg, Sep 5, 2005.
  1. paulg
    paulg
    Hello all
    I was wondering which of the current LCDs are best for freeview as I dont have sky ( And wont either ) - I will however be getting my Xbox 360 when it is released so want Hi Def - Was looking at the 32" Panasonic but was wondering if there were any that showed Digital well as have been disapointed with this models PQ.
    Thank you
    :clap:
  2. Phil from 62
    Phil from 62
    Jun 14, 2005
    59
    Essex
    My Loewe 32" has Freeview and the picture is good and thats not using a particularly great aerial.
    Its only disadvantage is that it is not enabled for digital Interactive (red button) services.
    Picture though...I would recommend.
  3. andrewfee
    andrewfee
    Apr 27, 2004
    3,061
    +500
    The Sharp "P" series will give you the best quality freeview signal... however it'll have to downscale Xbox 360.
    Really you have to make a choice as to which is more important; Freeview, or DVD's / High-Definition video/games.
    If Freeview is more important, go with the Sharp "P" if not, there are quite a few sets you could go with. The new Sony "V" series is said to be one of the better televisions for Freeview.
  4. paulg
    paulg
    Looks like I might have ti suffer on SD for a while then to make the Xbox better :)
  5. paulg
    paulg
    Looks like I might have to suffer on SD for a while then to make the Xbox better :)
