LCD for bedroom £600 budget - suggestions?
Discussion in 'LCD & LED LCD TVs Forum' started by noddingdino, Dec 20, 2004.
Tags:
  1. noddingdino
    noddingdino
    The title says it all really...I would like to wall mount an LCD TV in the bedroom and have a budget of £600...can anyone suggest a couple of sets to look at? I'm completely new to the whole LCD thing!!!
    HAPPY CHRISTMAS! :)
  2. noddingdino
    noddingdino
    55 views and no replies...something tells me your all bored of these 'what should i buy' posts !!! :rotfl:
  3. Flashman
    Flashman
    Dec 3, 2002
    353
    Swindon, Wilts
    +11
    Err, yes, I think you're right! :D ......Every couple of days there's the same(ish) question.....Try a search through the forum, everyone has a different personal opinion.
    I have a "cheapo" Bush 17" LCD for the bedroom, but it does exactly what I want it to....For £600 you should get a decent set, depends on your size requirement.
  4. kotlewm
    kotlewm
    Jul 1, 2001
    216
    Fife, Scotland
    +8
    Aldi has the following available from the 27th Dec. 27" for only £599. Check out leaflets in-store for more info.
    Tevion 27" LCD TV
    Picture in Picture facility with size and position adjustable
    2 Channel viewing; TV/PC, TV/AV, TV/S-Video
    Ultra Slim design in aluminium casing
    Resolution: 1280x720
    170 degree viewing angle
    16.7 Million Colours
    2x8 Watt internal speakers (Nicam Stereo)
    Progressive Scan
    Connections:- VGA, DVI, 2x Scart & PC Audio
    3 Year Warranty with Pick up, Swap & Return Service Included
    £599.99
  5. noddingdino
    noddingdino
    thanks kotlewm I'll take a look!
  6. soup nazi
    soup nazi
    prices are heading in the right direction now.£599 a good price.
  7. JSW
    JSW
    Feb 21, 2002
    4,283
    Staffs
    +333
  8. beno
    beno
    hello - i would recommend you get the sharp 22" widescreen, its 599 from richer sounds, good value. if you decided to spend less you can get a 17" philips widescreen for 499.
  9. noddingdino
    noddingdino
    thanks Beno...I actually went to Richer Sounds yesterday to take a look at the Sharp...expectations were high but to be honest, it just 'looks' too small compared to it's non-widescreen counterparts. Although they do have quite a nice looking LG 20" reduced from 450 to 380 or a Beko 20" at 399
    any thought on these? i noticed today that John Lewis are doing the LG at 519...
  10. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,022
    Babel Sensurround
    +207
  11. stuart07970
    stuart07970
    Sep 28, 2004
    2,492
    Slough
    +285
    Buy the 17" wide Phillips ! (PF9945 i think?)
    Its a great set, and you get a radio and sleep/wake-up timer!
    And at www.unbeatable.co.uk its only £449!
    and thats a lot of change out of your budget for a great looking set!
    Merry Xmas
    Stuart
  12. po_man
    po_man
    Dec 23, 2004
    1,710
    St Albans
    +63
    I would certainly recommend the Toshiba 17WLT46 17" widescreen LCD which also comes with integrated tuner (FreeView) so you get approx 30 channels without the need for a seperate box. I've seen these go on the internet in the region of £490 - £540 and i know that it's been highly rated by "What Hi-Fi?" magazine.
    Also another to consider would be either the Toshiba 17WLTD46 or LG KZ-17LZ23 which both feature integrated DVD players (extremely handy for the bedroom). The Tosh should be available by mid Jan but the LG i've seen on the net for a very resonable £549.99.
    Hope this is of some help!
  13. Barton1967
    Barton1967
    Mar 1, 2004
    93
    Westcliff, Essex
    +8
    The picture in yesterday's paper shows a different model (in silver) to the German Aldi site.
  14. jimbob19
    jimbob19
    Sep 5, 2002
    1,543
    Dunstable
    +50
    Must admit the one on Aldi's UK website does not look as good as the German one. Looks a different model to me
  15. garygfx
    garygfx
    May 18, 2003
    130
    +14
    The size of the German Aldi screen is completely different too. No way is it the same model, therefore I would ignore the specs on the German site.
