LCD - Does higher res mean less screen door, future 1080 panels?
Discussion in 'Projectors, Screens & Video Processors' started by zoolap, Nov 25, 2004.
  1. zoolap
    zoolap
    Oct 2, 2001
    594
    Warwickshire
    +7
    Am I right in assuming that the common panels of modern lcd projectors squeeze in the number of pixels into roughly the same space:
    e.g. HS20 panel vs epson panel used by ae700/z3 etc
    Certainly the Hitachi TX100 had much more apparent screen door at same distance from screen than HS20 that I saw.
    What I'm trying to get at is: when they release 1080p based lcd projectors (e.g. based on the recently announced epson panels) will that mean that screen door becomes less apparent. If they are fitting a higher number of pixels in the same size panel then I would have thought that inter-pixel gap would be smaller. If this was the case then we would not then need the likes of smooth screen hence potentially giving us sharper picture.
    Apologies if it sounds a bit muddled, but I'm sure many of you clever people will be able to figure it out :D
    Was just looking at this:
    http://www.epson.co.jp/e/newsroom/news_2004_06_28.htm
    and noticed it refers to pixel pitch - I assume this refers to size of pixel rather than telling us anything about interpixel gap.
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,684
    Woking
    +230
    Basically, yes. The higher the resolution, the more and thus smaller pixels make up the image and the less you'll see 'screendoor'. For example, a 800x600 VGA resolution LCD will certainly show more pixelation than an XGA resolution one. The Panasonic's smooth screen technology is probably the best going and pixelation is non-existent, even inches from the screen. The picture still looks very sharp and Sony's new H50 is reported to look stunning when displaying a HD signal with minimal pixelation visable.
  3. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    'Pixel pitch' does indeed measure the pixel spacing, though exactly what it's measuring I don't know .. for CRTs one used to look for 24mm pitch for good-quality, high-density pixel structure.
  4. red16v
    red16v
    Aug 20, 2004
    552
    +5
    Hi KraGorn - I assume you mean 0.24mm ! Regards, yt.
  5. CooperUK
    CooperUK
    Jun 30, 2003
    2,208
    Hampshire
    +301
    Maybe he sits a very long way away from a gigantic screen?
  6. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    :p
    Indeed, I did mean .24mm
    A thought on the topic here .. it all depends of course on whether the 1080 panels are the same size as current 1280x720 (0.7 inch IIRC) as to whether screen-door will continue to diminish. I've no idea if they've reached the technological limit to pixel packing density.
  7. stuthemong
    stuthemong
    Dec 31, 2002
    457
    +6
    im sure i read they were going to 0.9" on the epson site, though i may be wrong.
    there is no reason why smaller pixels can obtain smaller interpixel gaps, but given its something consumers hate, they will no doubt be striving hard to reduce this - but i wouldnt say it was a knock on effect of more pixels in a display - just a drive to improve the tech.
    you can almost be certain that in 1 years time the lcd panels will be noticably improved over the current best of field.
