LCD Black Levels - will it improve?
Discussion in 'LCD & LED LCD TVs Forum' started by Ramspeed, Jun 27, 2005.
Tags:
  1. Ramspeed
    Ramspeed
    Apr 27, 2005
    532
    28
    +24
    Hi all
    Is there or will there be in the near future an LCD that can offer black levels to equal CRT and plasma? Of all the complaints aimed at LCD's this seems to be the one that keeps sticking.
  2. msg
    msg
    May 20, 2005
    458
    Darlington
    +10
    I think OLED technology (no backlight required) will provide the black levels required. As yet this is in its infancy and is just starting to be used for some mobile phone displays.
    Dave
  3. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    Watching in a darkened room LCD blak levels are inferior to CRT & plasma. LCD's have improved and probably will improve further but slowly. However, with ambient lighting and the possibility of reflections, it is a limitation that is soon forgotten. A stray reflection can soon render portion of a CRT or plasma screen unwatchable where as a LCD display will be watchable with little/any visible effect on contrast/black level. So if you do not intend to watch in a room free of possible source of reflections, black levels may be a limitation that you think it is.
    -Ian
  4. rockhard
    rockhard
    Wrong were in for a monumental improvement with the new Epson 1080P D5 panels improving ANSI numbers ( 1200 -2000 ) and with varaiable iris achieving CR of 10,000:1 ( can you say inky blacks ) .look out rainbow crowd the year of 1080P LCD is hear and CEDIA in the fall will be a big show with SED , OLED , HD-DVD and 1080P LCD :)
  5. richard plumb
    richard plumb
    Jan 27, 2002
    14,477
    Windsor
    +1,046
    except this is the LCD *TV* forum, not projector.
    Philips new system for next year is supposed to be able to alter the backlight dynamically per scanline. Supposed to improve contrast/black level a lot.
  6. alefsin
    alefsin
    Feb 15, 2005
    130
    Some of the better LCD monitors already have a black level on par or even bettern than pro level CRTs. So in short, yes, in near future we can expect LCD TVs to be as good as CRTs in color reproduction.
  7. rockhard
    rockhard
    "except this is the LCD *TV* forum, not projector. "
    Just what panels do you think the RPTV 's are using ? can you say D5 1080p from Epson .
  8. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Wrong forum buddy - this is the LCD screen based forum - RPT dispays are discussed in the "DLP Rear Projection TVs" forum.
  9. rockhard
    rockhard
    "Wrong forum buddy - this is the LCD screen based forum - RPT dispays are discussed in the "DLP Rear Projection TVs" forum."
    Just because this is a screen based forum doesn't mean the technology of the panels is any different . 1080P rersoultion panels in the smaller sizes debuting this fall from alot of manufacturers.
  10. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,424
    Somewhere in South Yorkshire
    +5,823
    ......and the "DLP Rear Projection TVs" forum is for DLP technology (hence the name!) - not LCD.
    An LCD RP TV is most properly discussed here, in my view.
  11. rockhard
    rockhard
    "....and the "DLP Rear Projection TVs" forum is for DLP technology (hence the name!) - not LCD."
    Did not mean to ruffle your feathers ...but I was discussing LCD ...and I prefer that technology over rainbow DLP...and it is what I own...
  12. ianh64
    ianh64
    Aug 7, 2004
    2,233
    +63
    Correct me if I am wrong, the Epson D5 1080p panel is approximately 0.9-inch used for projection systems?
    This forum is for flat screen LCD TV panels and PC monitors, ie 15" upwards - direct view.
    As mentioned before, there are seperate forums for
    DLP rear projection TV's or any RPTV that may use other technology
    and
    DLP & LCD Projectors
