LCD Above a Radiator!!!!
B
Bonnie_120580
I want to get a 37" LCD TV. Problem is only place it can go in the room is above a radiator, will this be a problem?
I remeber something at school about liquid crystals being affected by heat but could be getting myself confused.
Any help would be appreciated.
Ta
B
Bonnie_120580
Cheers guys.
The shelf is going to have to be a fairly hard sell to the missus but worth a shot (she thinks the room doesn't need a telly in it full stop.)
I have a space of 110cm above the radiator, I want a 32/37" screen, so i suppose I have about 40cm between the radiator and base.
Do you reckon this will be enough?
avinitski
personally i would be paranoid about the heat if there was no shelf to deflect the heat but i am by no means an expert in this matter.
B
Bonnie_120580
Not sure if it worth the risk. May have to re-evaluate.
Also I think having above a radiator would mean it was too high.
gasteropod
I wouldn't advise it, because it would make your LCD overheat. You're not supposed to leave them in direct sunlight, so above a radiator is a no-no as far as I'm concerned.
avinitski
just buy the biggest TV possible and tell your missus you cant have the heating on, problem solved :thumbsup:
