LC37GA4E question
Discussion in 'LCD & LED LCD TVs Forum' started by vgopal, Mar 11, 2005.
Tags:
  1. vgopal
    vgopal
    question for people with this screens,
    on the 37ga4e the speakers are detachable.
    is there a wire connecting them to the back of the panel to provide the sound?
    can these speakers be disconnected but still work?
    i want to disconnect the speakers form the side of the screen but still have sound from them. if they are disconnectable what type of connection is used to connect to the screen? phono cables?
    also does this screen allow the speakers on the screen to be used a centre input like some philips models.
    thanks
  2. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    Yes and Yes !
  3. MickyGee
    MickyGee
    Jan 6, 2005
    294
    Preston
    No connections required just longer wires for the speakers.
  4. vgopal
    vgopal
    ok so its speaker wires connecting the speakers?
    also what about the centre input thing
    just making sure of this.
    thanks
  5. LcdGuru
    LcdGuru
    It has a dedicated phono input for the center channel. The TV amp and speakers can be set to output either stereo from the selected source or the centre channel input. The setting is on the 'Option/Centre Channel' menu. Very cool.
  6. jimg
    jimg
    Jul 4, 2004
    826
    +58
    Great TV, I love mine! Are you sure you want to use the side speakers as your "centre" speaker? Do you not have a 5.1 system with a full set of speakers, it is so, so much better! IMHO
