LC32P50E - Backlight setting & sky remote
Discussion in 'LCD & LED LCD TVs Forum' started by jabberwocky-, Oct 22, 2005.
Tags:
  1. jabberwocky-
    jabberwocky-
    Jul 21, 2005
    247
    South East
    +4
    Hi.
    When I turn down the back light setting to OFF, I have noticed my SKY remote then does not work.
    Shifting backlight backup to say half-way, the remote works again....
    I have SKY connected via EXT1 via RGB to SKY box tv out scart.
    Can anyone with a LC32P50E or similar model test this???
    (I have previously posted saying it was a problem with the sets EXT2 scart, but this definatly seems to be the poblem)
  2. neilmcl
    neilmcl
    Oct 29, 2004
    6,238
    103
    Nottingham
    +292
    When you say turn Backlight to OFF, you mean turn it down to -8 don't you. In which case I've just done that and it didn't have any adverse effect on my Sky remote.
  3. jobseeker
    jobseeker
    Aug 24, 2004
    618
    +99
    I have found that the OPC can cause remote problems in some situations. I have two 26" sets and the one in my bedroom had a problem with its own remote just stopping working randomly. When I swapped it with the one downstairs, the one I put in the bedroom had the same problem, but the one I moved downstairs was then fine. The problem obviously related to the location of the set and/or surrounding equipment. The cure was to switch off the OPC. Now, whether this is connected to the problem you describe, I don't know.
  4. captaindobie
    captaindobie
    Apr 17, 2002
    592
    Scotland
    +21
    Since purchasing a SHARP LCD32GA5 earlier this year i have had problems controlling my SKY+ box. When switching the TV on, it takes a good 20-30 minutes before the SKY+ box responds properly (unless i have the remote 5cm away from the box!)
    I still have the same problem whether using the SKY+ remote or my Philips Pronto. I don't have OPC switched on and my backlight is set to (-4)
  5. jabberwocky-
    jabberwocky-
    Jul 21, 2005
    247
    South East
    +4
    Yes, -8, seems its just my telly then..
    thanks for your help. though.
    Other than this its a great TV :)
