LC32GA5 Backlight
Discussion in 'LCD & LED LCD TVs Forum' started by kerplunkuk, Apr 29, 2005.
Tags:
  1. kerplunkuk
    kerplunkuk
    I received my LC32GA5 today and I had been very pleased with it. Sky looked good and so did DVD's. I hooked the xbox up and Splinter cell looked gorgeous after fiddling with some settings.
    I then started to play links and the picture was poor, I went into the settings and tried to alter the backlight, but it will not budge from 0. The left and right arrows will move everything else in the advanced options bar backlight.
    Can anyone advise me of how to solve this problem?
  2. kerplunkuk
    kerplunkuk
    Plus can someone recommend good settings for gaming other than the standard option?
  3. ianjh
    ianjh
    Mar 5, 2005
    83
    Norwich
    Took delivery of the 26'' version yesterday - been fidling ever since!!!
    You need to select "USER' from the 'Picture mode' menu before you can alter the backlight setting - probably the same for the other settings too.
    ianjh
  4. kerplunkuk
    kerplunkuk
    Cheers mate, sorted.
