LC17 and long graphics card. help!
Discussion in 'Home Entertainment Computers' started by ho.will, Jun 11, 2009.
  1. ho.will
    ho.will
    May 6, 2009
    4
    :confused: I am currently using a 9800GT in my LC17 case. I have had to remove the middle drive cage as the card was too long.
    I am now looking for a shorter graphics card so that I can install 2 more drives in the middle drive bay.
    Does anyone have any suggestions as to what card I should buy which will allow me to fit my hard drives in the middle bay? I do the occasional gaming, and I am looking to purchase an ATI card this time, hopefully a 4870 and above.
  2. KalC
    KalC
    Oct 14, 2008
    718
    +58
  3. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    I am using a 4870X2 in my LC17. I think a 4870 will be the same and you will loose the 2nd drive bay.
    [​IMG]
    I have stuck an extra HDD in my DVD drive bay in a HDD silencer. This gives me 4 HDD slots.
  4. KalC
    KalC
    Oct 14, 2008
    718
    +58
    Thanks for correcting me Razor, I didnt take into account how much the HD would stick out of the actual bay.
  5. Razor
    Razor
    Dec 15, 2004
    37,726
    2
    +12,503
    Thats alright mate. An easy mistake to make. :smashin:
  6. ho.will
    ho.will
    May 6, 2009
    4
    Thanks...
    Is there perhaps another recommendation for an ati graphics card that you can recommend? Something in the 4xxx range which will fit in the LC17 case?
    I specced out my LC17 case based on your gaming thread, Razor, so thanks for all your advice so far. :thumbsup:
  7. Sheepish
    Sheepish
    Feb 4, 2009
    105
    +13
    This is my LC-13 (same internal layout at LC-17) with an ATI 4770. It fits with the cage and you will accomodate the extra length a hard drive will stick out BUT the card is in the way of the sata connections :(
    I am definately going to need more hard drives in the future (3x in the already) and I havent tested this but I THINK it might be possible to switch the cages round (one has lips for the drives to sit on inside, one doesnt) and mount 2 (poss 3) drives upside down in the 2nd cage. Not tried it myself yet so dont take my word for it.
    Another solution, if you have a full size ATX board with 2x PCI-E x16 slots, would be to put the graphics card in the lower slot. The card wouldnt interfere with the drive connections in the 1st cage unless it has a big chunky plastic heatsink housing and even then it might be ok depending on where the PCI-E slot is.
    An alternative to a standard 4770 is the Sapphire 4850 Vapor-X which is the same size (not a reference 4850 design).
    Hope this helps :)
