LC16M power button wiring
tinners
Please can someone with this case give me a helping hand.
When connecting up all the cables I seem to have 2 lots of power cables (ATX power / Ground) One set is for the front power button and the other seems to be for the imon remote control unit.
I have connected all the wires as per the instructions but cant see how I can get both the front button and the imon working at the same time. When I have the imon ones connected the front power button doesnt work.
Wonka
I have an LC20, but imagine the process is similar.
The Power switch connector from front panel goes onto the dual pin header from the VFD/IR module
The 2 single pins from the VFD/IR module (black & red) go into your motherboard.
job done :hiya:
tinners
...edit
Ignore me, I had tucked one of the cables under the mobo :suicide:
(the one with 2 pins which connects to the front panel (orange/green/red) cable)
