G
garsmi
Hello all,
I have been looking at buying a second screen for the family room either Plasma or LCD 37". I've come to the conclusion that the LCD would be a better buy and decided on a Sharp Aquos range either GA4E or GA5E.
I believe (although not sure) that the GA4E is now discontinued but still available if your lucky... is this true? I have managed to source a GA4E for what I think is a pretty good price £2090 INC VAT!! But I can get the GA5E for £2018 INC VAT... Which would be the better screen?
I believe the GA5E does not have DVI or HD ready? This is not a major problem as my current DVD Player Sony DAV-S400 has no DVI output and I will be running Sky + through a Digi Sender but a Sky + upgrade is possible in the next couple of years where I could move the LCD into the lounge and buy another for the family room. I don't know too much about DVI / HDTV so can someone confirm the GA4E is HDTV compatible? IF so, I guess this will be the one to go for right?
Any comments appreciated!!
Cheers.
Cheers.
