LC-37GA4E and DigiSender
Discussion in 'LCD & LED LCD TVs' started by garsmi, Feb 3, 2005.
  1. garsmi
    garsmi
    Hello all,
    Tonight I tried the DigiSender from my Sky + box to the LCD and got the shock of my life. The picture is just unwatchable, shaking, horizontal lines and moving vertical lines !!
    The DigiSender is about 3 years old and has a very dodgy Scart lead which is fixed to the unit... This will not help but I think the main problem is sending the picture through the airwaves.
    Can this plug into any of the Scart sockets on the LCD? I tried changing the setup which did improve but sadly still unwatchable
    Has anyone else tried running Sky through a DigiSender to an LCD? I'm wondering if the new DigiSenders are any better or if there is another solution. I want to be able to use the remote control from the other room. Are there any devices that will boost or improve the picture? Will running cable be any better?
    :lease:
    Many thanks
    Gareth
  2. jimg
    jimg
    Jul 4, 2004
    826
    +58
    I have exactly the same screen and have fantastic picture quality from SKY+. I thought the digisender was merely a remote control repeater, what connection do you have to the SKY+ box? If you are using the RF2 output you will get a poor picture as that is a composite signal.
  3. garsmi
    garsmi
    Hi jimg, when I plug the Sky+ box into the LCD I get a great picture through the supplied Scart cable. However, the DigiSender is sending the picture from Sky+ to the LCD in another room... this is where it gets ugly!
    The DigiSenders are pretty old so I am going to try the new models from Argos... Looks like these come with Scart and RCA/Phono connections. Which one of these should give me the best picture?
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    Hi Gareth,
    Are you sending the signal from the transmitter to the receiver then onto the Sharp LCD ? If so, the signal the tv is receiving is Composite. RF frequencies only have the bandwidth to send composite signals, RGB is too much for it. So all digisenders send a composite signal.
    That means, unfortunately with the Sharps picture quality on Composite, it will be a bad picture. Is there any way of cabling a Scart from the Sky box ?
    Richie.
  5. garsmi
    garsmi
    You are correct. Here's the setup to clarify.
    Sky+ -> DigiSender with Scart -> DigiSender Receiver -> LCD with Scart.
    I thought about cabling Scart but there's just too many obsticals!! I will see what the new DigiSenders are like, if they are no better I will simply return them bite the bullet and order Sky Multiroom.
  6. jimg
    jimg
    Jul 4, 2004
    826
    +58
    As Richie says it will never work properly with a transmitter, I have SKY+ with the 37GA4E in the lounge and the old SKY box in the bedroom on another smaller LCD. It is worth the £10 a month to get a decent picture. What have you got connected directly to the box then?
  7. garsmi
    garsmi
    The Sky+ box is connected to my 28" Sony CRT in the lounge. The LCD is in the family room. Giving Sky a call as we speak. Cheers!
  8. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    You can get 10m Scart cables you know !
    :D
    Richie.
