Lazy sub
BiggieBig
hi guys.....
not sure if theres much else I can do about this problem but thought I'd give it a go.
Have a Velodyne VX-10 Sub which keeps going off when the volume is too low (-50db) on my amp if that means anything to anyone.
The volume is still reasonable but the sub goes off. Have to pump the volume and then turn it down every 8mins.
I have no auto switch on the sub, I also have the Y connector for higher gain.
Increased the amps Sub out to +3db but that doesn't seem to help either.
any suggestions.....
bob1
Hi depsi when i had the sub i set the sub output to +10db on my sony amp and turned the volume down on the sub,anything less than about +7db and i was doing the same as you.Hope thats some help to you .What amp have you got?
BiggieBig
bob1,
thanks for the reply....
still v pleased with the sub. just sub switch off is the prob...
my amps a harmon kardon 507. i'll try and turn it too +7db but a bit worried that'll cause a bit of distortion. (gain too high and all that).
no harm in trying....
bob1
Also have a look at thread
bob1
I'm sure will get the levels right in the end ,i did and it worked great.
BiggieBig
set the sub out to +10db.
works great now :smashin:
turns on at arround -55db.
thanks
chris
can you not just leave it on all the time.....????
I have the same prob with my SVS in auto mode.
It takes quite a bit of volume to bring it out of stanby, so i just leave it on all the time.
BiggieBig
chris
no option for this. Sub only works in auto mode.....
not really a problem since i've increased the sub out on the amp as i'll be rearly be listening to anything under -55db
