Lazy - Delay
Discussion in 'AV Receivers & Amplifiers' started by Dubbing Mixer, Feb 18, 2005.
  1. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    I know this is lazy but, to save me trawling through page after page of specs, does anyone know the cheapest AV amp or receiver with variable lip sync delay, digital co-ax in and 5.1 pre-outs. Don't need anything else fancy and I won't be using the power amps.
    Many thanks!
  2. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Bump!
    C'mon guys, someone must have a cheap amp/rec with these specs?
  3. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    Maybe we're too lazy to tell ya! :D
  4. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Given the number of models out there and the difficulty of getting hold of detailed (and accurate) specs, you can see how I might want a bit of help. I'm well aware that the top of the range models from several manufacturers will answer the requirements but they are serious overkill for what I have in mind. Hence the question. So, not so lazy, more frustrated ;-)
  5. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    Maybe take a look at the Yamaha range. Ive always had Yamaha and have always been more than happy with them. Im sure their lower spec models will have all that you are looking for. What kind of cash you looking to spend?
  6. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    As little as I can get away with, I'm afraid. So long as I get the variable delay and 5.1 pre-outs
  7. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Thanks GeeWcee,
    I checked out the Yammys and, at current street prices the 750 answers the requirements.
    I'd still be interested in hearing about alternatives though.
    I've been trawling through specs and even the ones that have lipsync delay adjustment seem very reticent about it. Its usually buried somewhere on the manufacturers website, not in the standard brochures.
  8. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    get the yammie, get the yammie!
  9. sisko
    sisko
    Nov 8, 2002
    496
    Comber, N Ireland
    +26
    I got a Yam 750 the other week and can recommend it highly.
    Excellent performer and lip synch delay too.
  10. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Thanks again GeWCee and sisko,
    Now seriously tempted. Did you check out Denon on the way to your decisions? (Only other one in the ballpark so far)
  11. sisko
    sisko
    Nov 8, 2002
    496
    Comber, N Ireland
    +26
    Thought about the Denon, but simple reason is Richer Sounds had the Yamaha in stock and at £349 you can't go wrong.
  12. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    Yes I did before, but I have to admit that I didnt demo any of the new denons when upgrading to the 1400.
  13. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Once again, thanks guys,
    Demos dangerous anyway with amps/receivers unless with your speakers. Either of you using the video up conversion to component? If so, are you happy? (This is an afterthought since the Yammies do it anyway)
  14. geeWcee
    geeWcee
    Oct 27, 2003
    1,420
    West Yorkshire
    +26
    Yes I use the up conversion on my dvd recorder and xbox (connected via s-video).
    DVD player is thru the component input into the Amp.
    Excellent picture quality.
  15. Loewe
    Loewe
    I guess Yamaha rxv-650 is the cheapest AV receiver with both variable lip sync delay, digital co-ax in and 5.1 pre-outs.
  16. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    Thanks Loewe, and welcome to the forums.
    I've checked out the Yamahas and I may well go for a model or two higher than the 650 but it does, as you say, do what I asked.
