Layout of 5.1 Speakers (rear especially), would this work well?
Discussion in 'Home Cinema Buying & Building' started by RaxSteve, Jan 24, 2008.
  1. RaxSteve
    RaxSteve
    May 17, 2006
    16
    3
    What i am looking for suggestions on is, what can i really do with the rear speaker placement. The room isnt too big (4.2m * 3.6m) roughly. The image I attached isnt exactly to scale. but to maximise space the corner sofa will have to go into the bottom left corner. I was thinking of placing the speakers above on mounts (but there is the problem of the sound going right over my head when watching movies etc). Would it probabbly be alright to angle the speakers down more than usual or would it be best to shift the sofa down. (bearing in mind there is a computer desk/chair in the bottom right corner.)
    I was thinking of getting some Quad L-lites for the speakers, so if it helps for the sizes of them. Due to the door being at the front of the room im going to mount them high up angled downward to get the most sound from them.
    Any tips or alternatives would be great thank you.
