Layer change problem on goodmans 3600pkt
Discussion in 'Blu-ray & DVD Players & Recorders' started by northernpaul, Dec 16, 2002.
  1. northernpaul
    northernpaul
    Hi all,
    I got a Goodmans 3600pkt recently (cheap I know, but decent with 5.1 and such), but whenever a dvd changes layers, the on-screen display shows 'play' in the top corner. This is fine when you first insert the dvd, but really annoying when half way through the film it does it when nothing is pressed on the remote.
    I have tried allsorts but can't get rid of it. Has anyone else had a similar problem and managed to sort it out? Any help would be hugely appreciated as otherwise the system is great.
    Thanks a lot,
    Paul
    p.s. I found in a thread that the region-hack works on the Grundig GCV720HT, Universum DR1020, Palladium STS-25, United DVH3161 and Venturer STS21, I don't know if that means they have the same firmware or anything, but if it helps...
