Latest Voodoo-2 driver, anyone?
Discussion in 'General Video Gaming Chat' started by Dr.Rock, Apr 24, 2002.
  1. Dr.Rock
    Dr.Rock
    Jan 10, 2002
    694
    London, UK.
    +38
    Can someone please tell me where I can get the latest driver/patch (Direct-X 8 compatible) for my 3dFX Voodoo-2 card? The latest Direct-X doesn't upgrade my Voodoo driver. The latest game demos (eg "Star Wars: Starfighter") won't run and complain that it can't find my 3D Card or that it doesn't have the latest driver. I am also using a Riva TNT2 Velocity 4400 as my primary VGA card. The Voodoo-2 is an add-on card, not an all-in-one. Thanks.
  2. laurel
    laurel
    Dr.Rock
    You do know that 3dfx were taken over by nVidia and there products were discontinued?
    Driver development stopped some time ago for Voodoo 2, Anyway, you can access all the available drivers from http://www.voodoofiles.com
    Don't think your gonna get DX8 versions though. I think DX7 was the last to be supported (even that in beta not final release). You'll need to suck it and see.
    You didn't say which ops. system you are using? If it's xp - no chance. 2000 there are beta drivers.
    You want to check out http://www.nvidia.com/ for the latest TNT2 drivers.
    Laurel
