Latest Software
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by mrjums, Jan 17, 2004.
  1. mrjums
    mrjums
    Up until approx 1 year ago I was creating DVDs from my DV digital Camera. The software I used to acheive this was as follows:
    Dazzle DV MainActor - to capture the DV tape onto my HD.
    TMPEGEnc Plus 2.54 - to convert the raw avi files into DVD Compliant MPegs (set at the max 8000 kbs).
    TMPEGEnc Plus 2.54 Tools to Join all the mpegs together.
    Ulead DVD Moviefactory to create/burn the dvd with chapters.
    Although the entire process and the methods I use seems a little long-winded and very time consuming, the end result works well with top quality digital video.
    My question is this:
    Is there a better/faster way of achieving this using different software.
    I am out-of-touch with the latest software so can anyone recomend better software to replace what im currently using.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,335
    Rainham Essex
    +2,433
    The newer version Ulead DVD Moviefactory 2 can do all you require. The capture is fine, but the editing is very simple with no features to add wipes, title & effects so if these are required any other editing package including the free MS Movie Maker 2 that comes with Windows XP wil do all that.
    Once you have the footage editeed as required Ulead DVD Moviefactory 2 does everything else. It's the software that I use and it does give very good results and is easy to use.
    Mark.
