M
mrjums
Up until approx 1 year ago I was creating DVDs from my DV digital Camera. The software I used to acheive this was as follows:
Dazzle DV MainActor - to capture the DV tape onto my HD.
TMPEGEnc Plus 2.54 - to convert the raw avi files into DVD Compliant MPegs (set at the max 8000 kbs).
TMPEGEnc Plus 2.54 Tools to Join all the mpegs together.
Ulead DVD Moviefactory to create/burn the dvd with chapters.
Although the entire process and the methods I use seems a little long-winded and very time consuming, the end result works well with top quality digital video.
My question is this:
Is there a better/faster way of achieving this using different software.
I am out-of-touch with the latest software so can anyone recomend better software to replace what im currently using.
