Latest on my Barco Data 808s focus
Discussion in 'Projectors, Screens & Video Processors' started by Leon Rees, Apr 18, 2001.
  1. Leon Rees
    Leon Rees
    Just posting an update to my left-right focus problem with my Barco Data 808s.
    I was having trouble bringing the both the left and right side of the green lens into focus simultaneously ... either optically or electronically.
    Well, last night I decided to take the green lens off and verify the washers were being used correctly. They were, but after putting the lens back on, the focus improved!
    I can only assume that the lens wasn't on its mount tightly enough.
    I now have a new problem...
    Thanks,
    Leon
