Latest Nvidia Drivers Problem
Discussion in 'Computer Components' started by Jean Valjean, Jun 17, 2009.
  1. Jean Valjean
    Jean Valjean
    Dec 12, 2008
    1,751
    Paris, France
    +280
    Anybody else having problems with the nvidia drivers.
    I have a Acer Aspire X3200 (quad core version) with Geforce 8200
    HDMI audio worked fine out the box, but when i upgrade the drivers either through Windows update or through Nvidias website it results in the sound turning into static blips.
    I then have to rollback the drivers to the previous version.
  2. The Ectogene
    The Ectogene
    Jul 10, 2009
    10
    preston
    my new nvidia driver (gfx6600) wont install properly either, do i need to uninstall the old one first cos i tried that and cleaned my my reg and still nothing. thanks
  3. Paul Shirley
    Paul Shirley
    Sep 27, 2004
    1,354
    63
    +174
    Uninstalling and nuking the mess left by the uninstaller (Driver Cleaner Pro is old but still effective) fixes most Nvidia update/reinstall problems.
    Otherwise your options are probably between learning about mixing driver releases (or finding someone that already did it) or rollback and waiting for a fix. Took nearly a year last time they broke my install though and it seems a regular occurrence.
  4. olpers101
    olpers101
    Jul 15, 2009
    130
    +5
    Nvidia drivers sometime get quite really clumsy. Updating them is good but make sure you make restore point before installing new drivers.
