Latest HTPC Build
Discussion in 'Home Entertainment Computers' started by aways987, Feb 16, 2014.
  1. aways987
    aways987
    Jan 31, 2013
    90
    Leigh-on-Sea
    +12
    Last month I finished my latest HTPC build. This system is designed to go in my new home cinema which is under construction (pics coming soon).
    The specifications are as follows:
    Case: Fractal Design 304 Node Black
    Processor: AMD APU A8 6500 4.1GHz Socket FM2 4MB Cache
    PSU: Be Quiet E9 StraightPower 480W Modular PSU
    Motherboard: Asrock FM2A85X-ITX Socket FM2 VGA DVI HDMI 7.1 Channel audio Mini ITX
    Primary HDD: Kingston 240GB HyperX 3K SSD
    HDDS: 3 x WD Red 4TB Drives
    RAM: 8GB Kingston HyperX Predator RAM clocked at 1866 MHz
    TV Tuner: Dual Freeview TBS PCI-e tuner
    OS: Windows 7 Home Premium
    Software: Media Center and MyMovies
  2. philhendo
    philhendo
    Jun 14, 2012
    14
    How's it running mate? What was your build cost? Phil
  3. aways987
    aways987
    Jan 31, 2013
    90
    Leigh-on-Sea
    +12
    It's running really well. The boot speed is insane, from turning on the power to MCE is about 7 seconds. The only issue that I have got is I had to use the stock CPU cooler as the other one I bought wouldn't fit due to the high profile of the RAM.
    The build cost was about £1150. I will be adding 3 more 4TB drives in the coming months.
  4. philhendo
    philhendo
    Jun 14, 2012
    14
    Sounds lightening quick mate shame about the cooler, you notice audible fan noise? You using remote or small form keyboard? You are basically using this as an all in one htpc and server by the sounds of it, that's what I'll be aiming for as I have raspberry pi and a roku3 for my additional rooms.
  5. aways987
    aways987
    Jan 31, 2013
    90
    Leigh-on-Sea
    +12
    I used the software that comes with the motherboard to limit the speed of the fan so it can't be heard. I am using the Harmony Ultimate remote.
    Yeah it's used both as a HTPC and media server. I have managed to get hold of two Linksys Media Center extenders do this drives those as well as being used for torrenting.
    What's it like using a Raspberry Pi?
