Latest Firmwear and Softwear for FMJ DV27A?
Discussion in 'Arcam Owners' Forum' started by spazzbecker, Oct 17, 2004.
Tags:
  1. spazzbecker
    spazzbecker
    May 27, 2004
    110
    +9
    Hello,
    I'm having an issue with some DVD's when playing the picture will "freeze" up then skip. It doesn’t happen on all DVD's just some also will skip when playing some CD's as well.
    I was thinking has there been an update to correct this problem?
    Hears my latest Softwear and Firmwear
    SW Version: 4.18.0/LT76/01/FF
    Mech. Firmwear version: LT76
    Is there anywhere I can download the current versions or maybe some one could email them for me... Please
    Carl
  2. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    5.13 is the latest, you have to request it from your dealer. There doesn't appear to be anything relating freezing/skipping in the release notes.
  3. PlanetGaffnet
    PlanetGaffnet
    What does 5.13 upgrade/fix? Will it work on a DV78?
    Thanks.
  4. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
  5. spazzbecker
    spazzbecker
    May 27, 2004
    110
    +9
    Just a quick note...
    Well yesterday 20 Oct at 10.00am I called Arcam tech line and asked them about the latest firmwear and softwear...
    Well TODAY 21 Oct I received in the post two discs from Arcam the latest softwear (5.13) and firmwear(LT78).. On two seperate discs... Flashed the softwear and Firmwear..
    Now my Arcam DV27A is all up to date :)
    Cheers Arcam
    They have the best customer service!!!!!!
    :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup: :thumbsup:
  6. AndoverRed
    AndoverRed
    Sep 24, 2004
    252
    Andover
    +5
    Carl
    Any chance you could send me the discs or copy them?
    Mark
  7. RaceTripper
    RaceTripper
    Jan 13, 2004
    537
    USA
    I have LT76 firmware.
    What does LT78 change?
    Does it fix the problem where hitting STATUS on the remote sends the player into SETUP instead?
