Laser. Gun. Strange Request
Discussion in 'General Chat' started by Member 328449, Apr 13, 2016.
  1. Member 328449
    Member 328449
    Aug 31, 2007
    3,420
    Kent
    +340
    I'm trying to figure out how to make a device which has a laser gun and a target. When the laser hits the target it changes the message on a connected screen. Anyone smart enough to work out how this could be done as I am not!
  2. MrSossidge
    MrSossidge
    Jan 7, 2006
    6,227
    East Riding of Yorkshire
    +5,153
    Ooh, could you repurpose a Tin Can Alley with an arduino or a Raspbery Pi and some wires and some crocodile clips?
  3. Member 328449
    Member 328449
    Aug 31, 2007
    3,420
    Kent
    +340
    That's the sort of thing I was thinking of to be honest. No idea how I'd make it though.
  4. HouseTonyStark
    HouseTonyStark
    Jul 11, 2006
    2,879
    5
    +541
    i imagine a simple light sensor input might work. if they work the way i think, it would record light levels, and as such you could just set a threshold in software to trigger from. this might get the result you need?
  5. balidey
    balidey
    Jan 2, 2009
    3,664
    +3,537
    I think most photo sensors would be switched on by the ambient light.
    I think a laser would trigger one, but I think it would need to be shrouded or partially hidden from most light, then a well placed laser hit would close the circuit.
    I seem to remember there were some electronics kits on ebay a while ago that were 'GPRS switches' but when you looked at them it was a photo sensor that you place in front of a mobile phone screen, then when you ring the phone the screen comes on and turns on the device.
    I would start with one of those and adapt it.
    Can't look for them right now as work don't like us using ebay.
  6. balidey
    balidey
    Jan 2, 2009
    3,664
    +3,537
    Or one of these kits as a starting point?
    Google: velleman mk125
  7. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,673
    +1,575
    We use a virtual spray wall - where you "paint" on a screen using spray cans that emit a UV laser beam.
    Behind the screen is a UV camera, which once calibrated can read the exact position of the laser. Works up to about 15M from the sensor.
    About £600 for the sensor and software, so maybe a bit expensive for this application?
