Large screen LCD with widescreen pc input
Discussion in 'LCD & LED LCD TVs Forum' started by mannyo, Feb 6, 2005.
Tags:
  1. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    First post here, nice forums.
    I am UK based and looking for a large widescreen LCD TV (27-30 inch) that is capable of handling a pc input resolution of either 1280x768 or 1280x720 via the standard vga input or dvi connection.
    We have already tried a Toshiba 30WL46B and although this has a screen resolution of 1280x768 the maximum that can be sent from a PC to the dvi connection is 1024x768. I can put 1280x768 in via the standard vga connection but the TV scales the image to 1024x768 resulting in text corruption.
    The reason is that I want to hook up my Mediacenter 2005 setup into this connection rather than use S-Video. I currently use svideo into my 32" Sony Widescreen set at a resolution of 1024x576 (UK Pal).
    Sorry if this is the wrong forum.
  2. eddie_talbot
    eddie_talbot
    Jun 11, 2003
    112
    16
    You're at the right forum :)
    The Toshiba's inability to handle the full resolution is the one thing that has put me off this set.
    You could take a look at the ProLite C300WT (30") or C270WT (27") by Iiyama. Iiyama makes PC monitors and have designed their LCD TVs to take PC input perfectly as well. If you're happy with VGA input only these might be an option.
    http://www.iiyama.co.uk/default.asp?SID=&NAV=236&PCAT=0
    I have no idea what their picture quality is like because I haven't seen one - most probably quite not up to the par of the Philips and Sharp sets that are raved about on these boards but reasonably good I'd imagine.
  3. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    Thanks for that Eddie.
    I have read a review of the viewsonic 30" N3000W, does anyone have any experience of the tv who can tell me what the pic quality is like from the dvi connection with a PC hookup at 1280x768. My TV feed is currently provided by 2 freeview PCI cards in mce2005.
    For the tv itself check http://www.viewsoniceurope.com/UK/Products/LCDTV/NextVisionN3000w.htm
  4. imh
    imh
    Right forum :) Why only 1280x768/720? Plenty of screens now support 1366X768, and some like the Sharps can handle VGA at almost that resolution.
  5. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    I think if I go to much higher the pc graphics card may start having problems with the 25fps required to display uk pal tv. I am using a Gforce FX5500 at the moment.
  6. imh
    imh
    Could be right, can you connect it to your PC monitor and see how high it will go?
  7. mannyo
    mannyo
    Feb 6, 2005
    758
    28
    Blandford Forum
    +77
    it seems ok with that resolution (1280x768) but at the moment cant go higher because my tft monitor doesnt support higher resolutions.
  8. shaddow2005
    shaddow2005
    Mar 23, 2005
    204
    I **VERY** nearly bought it as it Seemed to be HDCP also, but then they changed their minds :-( Boo.
    http://www.avforums.com/forums/showthread.php?t=188015&highlight=video7
    Probably still worth a look, if pc input is your main objective as its only around £850, (other rebadged versions are goodmans (comet) and grundig too) - note the specs may differ.
    It's just not going to work with SKY HDTV next year.
