large or small
Discussion in 'Home Cinema Speakers' started by clancol, Sep 18, 2003.
  1. clancol
    clancol
    Sep 6, 2003
    1,034
    38
    Middlesbrough
    +7
    I thought i had my amp set to the correct settings, until i read some of the other threds about front, sub settings and now im not so sure.
    I know that my mordaunt short 908s are large speakers. but should they be set to large on the amp.
    I also have an eltax A12 soon to be upgraded to a pardigm pw2200.
    what should the settings be for these.
    Currently they are set
    fonts large
    sub ON
    Center&rears small
    is this correct
  2. dunkyboy
    dunkyboy
    Jun 5, 2002
    635
    London
    +6
    I think the sheer quantity of debate on this issue leaves one thing (and only one thing) perfectly clear: there is no "correct" setting, just different settings for different circumstances and tastes. Have you tried other settings? Which one sounds best to you? Go with that.
    Dunc
