Laptops with display port out
Discussion in 'Desktop & Laptop Computers Forum' started by johnieutah, Feb 26, 2013.
  1. johnieutah
    johnieutah
    Nov 9, 2006
    632
    28
    +25
    Looking for a new laptop for my photography work.
    I want to drive a high res 27" monitor which I believe can only be acheived with display port. However I only seem to be able to find Dells and Macs with this option. Others just have regular HDMI.
    Any further manufacturer suggestions?
    cheers. :smashin:
  2. trjp
    trjp
    Dec 12, 2006
    167
    +20
    Displayports are really only found on business-aimed laptops - consumer devices get HDMI instead (cos consumers have TVs and not high-res monitors and projectors)...
    HDMI 1.4 increased bandwidth so that you can run higher-res but not at massive refresh rates (it will go to 4096x2160 but only at 24hz) - see here
    HDMI - Wikipedia, the free encyclopedia
    Displayport 1.2 can do a bit better
    DisplayPort - Wikipedia, the free encyclopedia
    So it really depends how high you want to go - if you really need Displayport, you'll need to shop for corporate laptops (so the Dell/HP/Lenovo Business stores) OR pickup a recond/refurb if the budget is tight (corporate laptops tend to the pricey end of the spectrum).
    p.s. remember that you'll need a LOT of graphics memory too - and oddly, that's something business laptops tend not to have - bit of a catch-22 then...
  3. johnieutah
    johnieutah
    Nov 9, 2006
    632
    28
    +25
    Thanks for that. From what I understand, only a handful of monitors accept 2560 x 1440 over HDMI... was after a Dell 2713 but that only goes up to HD over HDMI :-(
  4. brookheather
    brookheather
    Nov 20, 2005
    5,300
    London
    +930
  5. johnieutah
    johnieutah
    Nov 9, 2006
    632
    28
    +25
    Looks like this is doing some sort of compression on the video signal, I wonder if this has significant hit on performance. My problem with all this is that HDMI 1.4 supports higher resolutions, but both the sending GPU and the receiving monitor need to support this. Which is not the case.
    Will stick to Dell as Mac is not an option.
  6. brookheather
    brookheather
    Nov 20, 2005
    5,300
    London
    +930
    On a modern laptop with a Core i cpu you won't notice any performance hit.
