virtual_boy
Its a HP G6060EA less than 12 months old and running Vista, it wont boot while the battery is in situe even if its plugged into the mains.
The power light comes on but the screen remains black for 10 seconds then the backlight comes on and shows a blinking cursor, the cursor blinks a few times before rebooting... over... and over... and over...
As soon as the battery is removed it will boot fine, after which I can replace the battery and use as normal.
Im stumped!
Im stumped!
