Laptop with WMHD compatability ?
Discussion in 'Desktop & Laptop Computers Forum' started by HeweyBoy101, May 1, 2005.
  1. HeweyBoy101
    HeweyBoy101
    Jul 9, 2004
    856
    Lancing, West Sussex
    +60
    Just a quick question. I'm about to buy a laptop for home / family use. What is the minimum spec I should look for to make sure it can play back Windows Media High Def material. My current desktop PC can do this Ok, although it does seem to stutter a bit on 1080i material (720p seems OK). Current PC is 2.66 mhz processor. 512mb RAM. Laptop's I've seen have P4 processors and 3.06 mhz or 3.20 mhz speeds respectively.
    I'm not likely to play / watch on the laptop, but may use it to connect to my Plasma.
    Thanks.
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    Toshiba have a New Home Entertainment laptop out have a look at that.
